Question about SINGER 7470 Sewing Machine
The needle is hitting the metal under the bobbin casing on my Singer 7470. How do I fix it? Thanks! Ashley
  • 54 Answers
You machine is out of timing bad,,may have a broken gear.
Posted on Aug 19, 2010
Hi, I have a singer confidence 7470 sewing machine and the needle keeps hitting the bottom of the bobbin. I need to know how I can adjust the needle.
Try a brand new needle. If the old one is bent, that could be why it is striking. If the new needle doesn't resolve the issue, the machine most likely has a timing issue. You can search for multiple web sites and videos for discussions and instructions for sewing machine timing issues. Or you can take it for service.
Oct 04, 2016 | Singer 7470 Confidence Sewing Machine
My sewing machine jammed the fabric into the bobbin case and now it won't sew the needle hits the plate under the bobbin case can I adjust this myself
Here are some videos that may help. If not, search the internet for thread jam.
How to Fix Thread Jam Sewing Machine
When Thread is Caught in Sewing Machine Sewing Lessons
https://www.youtube.com/watch?v=tDcBUR0PcyA
If you get it unjammed, be sure to install a new needle as the old one is probably damaged. If there are still issues, the machine's timing may be off and would need professional service.
Oct 23, 2015 | Singer 7470 Confidence Sewing Machine
My singer 7470 i start to sew and clicks and bunches the cotton then the bobbin catches on the hook
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
if these suggestion don't help then the machine needs to be checked to see if it needs some type of adjustments
Mar 19, 2014 | Singer 7470 Computerized Sewing Machine
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
May 11, 2011 | SINGER 7470 Sewing Machine
I have a 5050c singer The bobbin case jump out and now the needle hits on the metal plate that is under the bobbin case. How do I fix this ?
I think that you have had the wrong size bobbin. It should be a class 66. Look in your manual, it should tell you. If, that is not it, call Singer at 1-800-4singer and ask if it sounds like the timing and if so where can you take it to get fixed. This is a nice machine, my friend, has one and it is worth getting fixed if you like it.
Jan 01, 2011 | Singer 5050 Mechanical Sewing Machine
My singer 7470 is skipping stitches on the left hand side ie. if im doing letters it misses the bottom 1/3rd. and other wider patterns misses about 1 in 12 ? i have cleaned bobbin case and it has obviously...
Take the machine in for service by an authorized Singer tech.
Hitting the bobbin case may have knocked the timing off and the shuttle may have to be replaced.
Trying to fix this yourself may lead to more problems and additional expense.
Mar 27, 2010 | SINGER 7470 Sewing Machine
New Problem...I have a Singer CG-550. When I try and sew anything, the needle hits something inside where the bobbin is. The little black casing holing the bobbin keeps moving all over the place, I slip...
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Mar 06, 2010 | Singer Sewing Machines
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue?...
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Apr 15, 2009 | Singer 7436 - INGENUITY
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
SINGER 7470 Sewing Machine Logo
217 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
