Question about Sony NWZB133F MP3 Player
My Sony NWZB133F MP3 Player could not on because it had hit the wall. is it already break? it won't on even after i put it on computer.
  • 105 Answers
Probably hardware is broken.., fin a local technician or electronic repair shops and let them check it for you...
Posted on Jun 06, 2010
I have the same problem as others. I was trying to erase all of the music from my player ( NWZ-B133F) and hit "format" and lost everything....just a white line with a black background. I tried to...
The original operating software will have to be installed by the authorized service center . Only then the device will get recognized by the PC
Jul 31, 2011 | Sony NWZB133F MP3 Player
Not connet on computer
Hi, Sony NWZB133F MP3 Player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sony NWZB133F MP3 Player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sony NWZB133F MP3 Player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sony NWZB133F MP3 Player can connect to your computer in MSC or MTP mode. Exceptions are Sony NWZB133F MP3 Player Connect and Sony NWZB133F MP3 Player Express which only use MTP mode. MTP mode is the recommended and default method for Sony NWZB133F MP3 Player when used with Windows OS.
The Sony NWZB133F MP3 Player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 22, 2011 | Sony NWZB133F MP3 Player
My sony digtal music player nwz-B133F always show format error
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblProblem">my Sony NWZB133F (1 GB) MP3 Player,is not getting on ,it shows boot error</span> <!-- from fixya rte -->
May 22, 2010 | Sony NWZB133F MP3 Player
Computer no longer recognizes my MP3
Have you attempted to re-install it to your computer. It sounds as if the driver has been corrupted.
Feb 11, 2010 | Sony NWZB133F MP3 Player
My nwzb133f won't turn on...even after resetting it and then it freezes. It won't even go to main menu so I can format it. I had just added more music and charged it. It also is not being recognised on my...
if you have the initial executing files that were on your mp3 when you bye,
Format your Mp3 on PC by FAT32 format and copy those on your Mp3 player folder
Oct 05, 2009 | Sony NWZB133F MP3 Player
I need operation guide for nwz-133f
Connect up your mp3 player to the computer through the usb cable. When it shows up on My Computer, click on it and the list of files already on it shows up. The operation guide is there in lots of languages.
loretogirl
Jan 03, 2009 | Sony NWZB133F MP3 Player
Sony Walkman can't function after format using Windows Explorer
hi! i have d same problem, no power. this happened after i transferred files to and from the mp3 player. Anyway, i already solved it. Try reset the unit. its located at the back of the unit, beside the earphone plug. It works for me. Hope this helps. Pls let me know if it did. :)
Dec 20, 2008 | Sony NWZB133F MP3 Player
Sony NWZB133F MP3 Player Logo
152 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
