Question about Kenmore 24032\24036 Top Load Washer
I have a Kenmore 70 series top loading washer. Model#11020702990. It is a type 111 It will not drain. It fills, agitates, but does not drain.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20702990&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the drain / spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jun 06, 2010
Kenmore 70 series model 11020702990
the part is a little rubber/plastic bushing that has wore out it is on the shaft coming off of motor to the other unit to work washer u should be able to see this when washer tilted up and see the wore part and is mildly easy fix unless this is a all enclosed unit with engine
Sep 03, 2012 | Kenmore 22422 Top Load Washer
Washer Kenmore 70 Series Model # 110.247323000 Serial# CR3845255 Type 111 Washer fills cold, warm, hot - no agitation - no draining
IF THE MOTOR DOES NOT RUN CHECK THE LID SWITCH. IF YOU HEAR IT RUNNING YOU MAY HAVE A BAD COUPLER.
Jan 12, 2010 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Have kenmore 70 series washer model #20702991 ser #1069231 type 111 will not drain. It starts the cycle by agitating then stops and will not go to drain cycle. switch on top lid does not ckick, tried...
The lid switch must close for the washer to spin. I've seen a lot of these break where it's mounted to the top. You may still be able to reach under the top to grab the switch to close it and get it to drain. You'll almost certainly need to replace the lid switch.
Jul 21, 2008 | Washing Machines
Kenmore Washer won't Agitate
gearbox internal fault, major repair, not really a do it yourself job.
Dec 25, 2007 | Washing Machines
Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
the drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
386 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
