Question about Dirt Devil Reaction Twin Cyclone Upright Vacuum
Handle release pedal replacement on Dirt Devil Reaction vacuum
I have a Dirt Devil Reaction vacuum that the handle release pedal popped out and because it was broken, I purchased a new pedal. Now that I have the part (and it is the right one), I can't get it into the vacuum correctly. How do I insert this part without breaking it?
debbily
  • 101 Answers
SOURCE: Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Posted on Oct 11, 2007
ukvacfan
  • 328 Answers
SOURCE: vacuum
Yep check the hose at the back as it may well be clogged. Also undo the soleplate/floorhead and have a look up the dirt channel behind the floor brush. Either that take off the main bin and check the dust channel leading down to the hose.
Posted on Dec 29, 2007
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Posted on Jan 15, 2009
galati2k
  • 281 Answers
SOURCE: Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Posted on Apr 08, 2009
  • 8 Answers
SOURCE: Dirt devil vacuum is screaming loud and barely picking up.
you need a new motor or a new machine that is unfixable
Posted on Jun 12, 2009
Why will my Dirt devil easy steamer not releasing cleaning solustion
Hi! You may need to prime the trigger to get the solution flowing. To prime the trigger recline the handle and pump the trigger vigorously about 30 times. Power the cleaner on and hold the trigger in for 30 seconds. Be sure you are only using the Dirt Devil cleaning products intended for use with this machine. Using something other than the specified detergent can clog the lines that deliver the solution. If your cleaner still isn't dispensing you can take it in to a Dirt Devil authorized service center for repair. I have included a link where you may go to locate a service center near you. Hope this was helpful!
May 22, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
How do you replace the handle release pedal
The handle release is just snapped into the bottom base. To take it out you will need to take a flat screw driver and pry the old one out. Then take the new one and pop it into place.
Dec 02, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
My dirt devil reaction is spitting out dirt everywhere. how do i fix this?
Sound like you have an obstruction in the suction path. check the foot (bottom) check for suction at the hose for blockage. the blockage is where you lose suction.
Oct 10, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Dirt devil bagless vacuum doesn't run,
unplug the vacuum and try tu turn the brush roller by hand a few turns .plug it back in and try it again.if not try another plug in the house.you might have a bad connection at the motor or the motor itself is bad
Dec 19, 2008 | Dirt Devil Featherlight Bagless Upright...
Aug 19, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
Dirt Devil upright vac
It could be a broken handle release, but it also could be the the clamps where the handle asm, and the base hold together came use, this will cause this problem on some Dirt Devils. The top has to come off to check this out.
Jul 13, 2008 | Kenmore Progressive Bagless Upright with...
Oct 01, 2007 | Vacuums
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
