Question about Insignia IS-LCDTV32 32 in. Television
Power wnet off and tv will not go back on - Insignia IS-LCDTV32 32 in. Television
    Problem Solver:
  • 9 Answers
Might sound daft but plug a lamp into the socket ware the tv was plugged in if that works check the fuse in the tv plug if all ok and still nothing unplug tv for a few hours and make sure power button is out (off) then plug back in then try power button and then try to start tv by the channel buttons on the tv instead of remote
Posted on Jun 05, 2010
F2 button not working
Fn plus CTRL plus F2 key?
Really.............
I haven't looked yet. Yep, just that lazy.
Most laptops have one single key to press, for the Display Toggle-Over key.
Per se such as hold the Fn key down, and tap once on the F2 key.
Post back in a Comment.
Regards,
joecoolvette
Mar 30, 2013 | MSI Wind U100-030US Laptop
My sony home theater emplifier just wnet off while playing, there's no sign of power,it cant switch on anymore
check in the back for a fuse, if no fuse in the back, it may be inside the case. If it's blown, there usually is a reason. also check to make sure that your speaker wires are not shorted, if they are they can burn up the output stage of your amp.
Mar 08, 2011 | Sony STR-DE595 5-Channel Amplifier
Tv has been turning off right after you turn it on then after a few attempts it would stay on now the power button on front turns green, it tries to come on but then turns off.
Sounds like high voltage power supply has gone bad. You can try purchasing new PS online and replacing yourself if handy or you will need to bring in for service.
Mar 04, 2011 | RCA HD52W59 HDTV Projection Television
Power window rear went down will not go up (maxima) 1996
hi buda 1. if u could remove the door pannel n have access to the motor for power window.having seen the motor try giving a few knock on the motor itself n try n see if that work.
Apr 27, 2009 | Nissan Maxima Cars & Trucks
Panasonic CT-36HL44J TV went dead, won't turn on.
have check for fuse? is your tv cord good?
Oct 24, 2008 | Panasonic CT-36HL43 36" TV
Sony Grand Wego - Sound but No Picture
Before I commit myself, I need a little more info. First, what is the model number? Second, in the front there should be a standby light. does it blink at all? It should blink in a repeating pattern. If so, please post that too.
Thanks,
Dan
Sep 23, 2008 | Televison & Video
RCA Colortrak plus. Model# F32672SB Serial # 807560570 Chassis # CTC187CJ3 Manufacture Date Feb 1998 Service # F32672SBFM3 4/21/08- TV worked fine last night. This morning worked for about an hour. ...
It's probably a cracked solder joint in the power supply / horizonal drive stages. As the unit heats up the joint is seperating and breaking connection. It could also be a component failing when it gets hot. Usually the voltage regulator or Horizonal Output Transistor (both mount to heat sinks).
If you know how to solder and want to tinker, unplug the set for a couple days (to let the power capacitors discharge) and resolder and crystalized it cracked joints on the board(s) where the power stages, and flyback transformer are located.
If you decide to operate the set with the back off, please be careful. The high voltage on a TV can be 30,000+ volts.
Hope that helps,
Geno
Apr 21, 2008 | Televison & Video
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
Toshiba projection tv 50 inch
Need to test F470 and F850 for open.. Simple continuity to see if either fuse is open.. If F 470 is open replace it and C884 and if F850 is open you probably you may need to replace the two convergence amps STK392-110... Large black Ic's screwed on an aluminum heat sink...
Bill
Dec 16, 2007 | Toshiba 50H72 50" Rear Projection...
Insignia IS-LCDTV32 32 in. Television Logo
128 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
