Our Mitsubishi Big Screen HDTV connected to an antenna
Keeps flashing to a black screen like an eye blinking intermittently and sporadically.
  • Karyn L Apr 10, 2008
    WS-55313 Black Screen
  • Anonymous Oct 20, 2008
    I have 2 problems., 1- the volume starts to increase to top high and decreasing to "0", 2- suddenly the image started to flash and flash, just like going on and off but instantaneously
  • 8,617 Answers
Can you post the model number of the set? Also is the picture going out to a black screen or a colored screen. Please elaborate if possible and I should be able to help you.
Posted on Apr 10, 2008
  • Sonny Berry
    Sonny Berry Apr 10, 2008
    That model has had some issues with bad solder around the Vertical output IC, yoke pin connections and also the flyback (H.V.Transformer) try resoldering those items see if that helps. If you need more info please let me know.
Why does my mitsubishi big screen tv keeps blinking
If its the lights by the on and off switches its the bulb,it should not have a picture maybe have sound only its around 40-80 dollars.Easy fix.if has picture a nd turns on and off its the color wheel
Jun 11, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a Mitsubishi WS-55313 55 in. Rear Projection HDTV. My problem is, the picture suddenly goes to a black screen, while the audio remains. When I turn the TV off, and then back on, I may or may not get...
your dose not use lamp, it is a crt driven TV . One of com problems for that model was loose connection on one of the yokes. When that normaly happens , there is a sudden flash and screen gose dark and sometimes it can flash back if not you get red light blinks. If you you know where the yokes are at check little small board . A small mirror will come in handy, access from front of TV. adios ... john
Mar 31, 2010 | Mitsubishi WS-55313 55" Rear Projection...
Why does my Mitsubishi Big Screen television keep turning off by itself?
probably had digital module, if it's intermittently doing to blinking green light, if not a blinking light, then probably solder connections on the board or yoke connectors.
Aug 31, 2009 | Mitsubishi WS-55511 55" Rear Projection...
65" Mitsubishi Projection Television keeps flashing black screen
check your closed caption, long time ago there were 4 cc options. Turn it completely off, that might get rid of it.
Jul 18, 2009 | Televison & Video
Blinking
Replace BOTH of your STK ICs .big black ICs will part number on them.
Feb 19, 2009 | Mitsubishi WS-55809 55" Rear Projection...
MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Nov 01, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Blinking screen
Good Day,
matty1234;
This common for this problem. try this:
Uneven colors with multicolored lines in the center of the picture and/or flashing, may also shutdown with a red lamp LED. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002).
I hope this was helpful,
Big IRISH.
Jul 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
