Question about Garden
I replaced the spark plug on grass cutter and it starts but wont stay running
  • 177 Answers
Sounds like flooding, carby service maybe required I'm guessing that it has been sitting for some time ,fuel has a tendency to go like jelly then hard like super glue and it blocks all jets
all machines that are small and that don't get used often should have a fuel turn off tap so you can run it dry (carby empty of fuel) meaning, whilst running, turn tap off, engine dies,carby empty no problems!!! it seems to be a common prob with small engines and all service centers are praying on this happening ,hope it helps if you are able put a fuel tap on approx cost $4 or get someone to do it ?
Posted on Jun 07, 2010
Just replaced carb new spark plug and new gas line. Will start and run for 2 minutes . When you press the throttle it dies and won't start again. Same problem I had before replacing carb.
Rick if you are sure it is fuel related issue, does sound like it may be running out of fuel. Check the fuel filter in the gas tank and replace, also check the fuel tank cap as the vent in it may be plugged,which will cause this issue.
A similar issue to this, is when the muffler screen gets plugged with carbon on some models. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Replace Chainsaw Fuel Filter
What to do if your chainsaw wont stay running
Symptoms Repair Of Clogged Spark Arrester On Grass Trimmer
Chainsaw Repair Help
Apr 14, 2016 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Not cutting
If the mower starts and runs, then shut it off.
Find the spark plug.
Now, tip the machine up on its side WITH THE SPARK PLUG UP.
(If you do not, and if you tip it the wrong way, you can fill the combustion chamber with oil and ruin the machine when you try to start it again.)
Once it is tipped, look under the machine, and feel the blade to see if it is tight or loose on the motor shaft, and also if it needs to be sharpened.
If loose, tighten it.
If dull, sharpen it.
God bless your efforts.
Apr 12, 2016 | Garden
Why don't I get a spark after replacing the coil on my Redmax grass cutter model TR2301S that is less than 3 years old.?
The gap between the coil and the magnets on the flywheel is critical. It is very close and needs a feeler gauge to be set. OR the magnets in the flywheel are bad.
Jan 22, 2016 | Cars & Trucks
Tanaka tht 2100-very difficult to start. Pull cord is is either too loose when pulled or it is jumpy, meeting with a bit of resistance?
i think it sounds like the motor is going i had a chainsaw and it did the same thing after a while the motor went and the chainsaw was no good anymore so you mite want to take it to a dealer that deals with your grass trimmer
Sep 03, 2012 | Tanaka Commercial Grade "Inspire" Design...
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
Kia ora, i have a makita 2 stroke grass cutter, that just wont start, checked, spark plug, fuel, took it apart and cleaned it..still wont start. Please help, it does not have model number only product...
Engines need 4 things: Spark, compression, fuel, exhaust
1) Does spark plug have spark?
Take out plug, put plug wire back on plug, hold plug threads against metal part of engine, pull cord, do you see spark between plug and engine?
2) While spark plug is out, put finger over hole and pull cord. Do you feel suction that shows compression?
3) What about the exhaust port? Is the screen blocked with carbon deposits and dirt? Soak it in WD-40.
4) Do you have 2-cycle oil in gasoline? Do you have fresh gas? Did you leave gasoline in tank for several months? Is the carburetor clogged with gum?
5) What about the air filter? Does it fire up without air filter? Will it fire if you spray WD-40 into carburetor? Can you keep it going while spraying WD-40 into carburetor?
If it fires with WD-40 but won't keep going on it's own, then the gas is not getting to carburetor or carburetor is clogged with gum.
Oct 08, 2010 | Makita Garden
Stihl 011 av wont start
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
May 07, 2010 | Oregon Scientific Complete Carburetor for...
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
Muculloch brush cutter wont start. No spark from plug.
If you have correctly diagnosed the problem as no spark, you will need to replace the ignition module. Unfortunately McCulloch dealers and McCulloch parts are very hard to find these days. If yoou do not have a dealer in yoour are who has the part you need, contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Sep 21, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Lawnboy 10301 won't start
you need spark, gas and timing to make it run. have you checked spark? sounds like you are getting gas. did you hit anything hard with the blade while mowing? this can throw it out of time.
May 23, 2009 | Garden
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
