Question about Acer Aspire 3680 Laptop
I have an Acer Aspire 3680, I had to do wipre my
I have an Acer Aspire 3680, I had to do wipe my hard drive clean and do a full recovery. I have the discs from Acer for my laptop. I performed the steps like the instructions said. Well for some reason its goes through all the necessary steps and then when my computer reboots, it says C drive needs to be checked for inconsisities and its fixes the problem. But when I reboot after that its says it caanot find the operating system to reinsert the system disc. Well that doesn't do anything. So I redo the recovery and now it takes like 5 hours to reformat the hard drive and once that finishes I insert the next disc like instructed but all it does is says its copying files and I don't see the light flashing where the disc is inserted. Can someone tell me what may be the problem of why its doing this. Also, I had to replace the hard drive like 6 mos ago. Don't know if that has anything to do with it but wanted to mention it. Any help would be appreciated...and if possible explain in detail becasue I'm not all the techinal savy...thanks all.
    Problem Solver:
  • 9 Answers
Sounds like the hard drive still when i re install on mine i take out hard drive re instert juast to be sure its in nice and straight no bent pins ect pop in your windows disc and turn on it normally says press any button to boot from cd so tap a button then you should follow the guide for install not repair then do quick format it wont take as long and is goos enough let it go to the point ware you can see a basic list of size of your hdd and partions just allow delete every thing then you should just see unpartioned space if 40gb then it would be 39000mb ect then install there that makes sure that nothing else is on you hdd that could mess with the boot if you are still not sure email me and i can send you a more detailed set by set guide its shaunhoop1981@googlemail.com
Posted on Jun 05, 2010
When i try the acer system recovery it keeps coming up with an error that says windows could not install and setup with resume when computer restarts..restarts ands same box pops up? cannot get past that...
Have you tried booting to the system recovery again and starting it over? Otherwise you may need to wipe it clean and start from scratch. Download a program like Darik's boot an dnuke to wipe the hard drive clean (this will destroy all data on the hard drive, including system recovery data if that is saved on the hard drive instead of CD's.) Then try the system recovery again (if it's on CD's)
Jun 24, 2011 | Acer Aspire One PC Notebook
0xa0000002 acer aspire 5315 recovery after new hard drive. Replaced the hard drive. got the system and recovery discs. system disc asks for language, then kicks out and asks for recovery. recovery disk...
make sure disc is clean wash gently with warm soapy water going from middle to outer edge then dry with soft cloth going from middle to outer edge make sure cdrom is set to boot first then put RECOVERY DISC in first when finished put system disc in.
hope this helps.
Apr 28, 2010 | Acer Aspire 5315 Notebook
Acer Aspire 3680 startup, blue screen & cursor only
  • prior to the recovery... have someone pull your hard drive and recover the "precious" files & pics on the drive... It's expensive at Best Buy... so watch out!!!
  • System recovery shouldn't have you loose all files.. if a recovery point is there... the trick is to only recover to the most recent point that you can. When Windows updates the software to Service Pack X for example, a recovery point would have been created automatically
Sep 13, 2009 | Acer Aspire 3680 Laptop
Resetting my acer aspire 3680
It is best to wipe it clean and start over again.
By this I mean format your hard disk and install Windows again, and install an anti-virus suite with firewall.
Check your ACER recovery and driver disk etc.
Apr 01, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680 can't find op system
THE CMOS BATTERY IS BAD REPLACE IT AND REBOOT SYSTEM.
THE SYSTEM DOESNT SEE A HARD DRIVE, CHECK THE CABLES TO THE HARD DRIVE CHECK THE POWER CONNECTIONS
FILL THE HARD DRIVE SEE IF YOU FILL MOVEMENT, IS IT WARM,
POWER SUPPLY MAY BE ANOTHER ISSUE
NO OPERATION , NO SYSTEM, NO CONFIGURATION, CMOS CLEARED, POWER SURGE, LOSS OF POWER,
ROD
Jan 11, 2009 | Acer Aspire 3680 Laptop
How do restart to factory settings-acer aspire 3680
Usually there is a factory image stored on the hard drive and you when you restart your system you hold down either the F8 Key or F10 Key and this should start the recovery wizard. Then you should be on your way
Dec 04, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 start up
This is generally caused by a hard drive failure. You can try to repair or reinstall the operating system with your recovery or operating system disc. If you have any issues or problems during or after the repair/reload then the hard rive has failed and will need to be replaced.
Jul 20, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Complete Restore
http://www.acerpanam.com/us Go to that website and click on "eRecovery Disc Purchase". Acer does not come with recovery discs. It only comes with a recovery partition from which you can make recovery discs. If they discs were not made you'll find the provided website useful. If you're trying to recover from your recovery partition, then continuously hit the F11 key at startup. This F11 option is not always displayed. If this doesn't work then your hard drive is corrupt or damaged and you will need the discs (and potentially a new hard drive).
Apr 13, 2008 | Acer Aspire 3690-2196 Notebook
Acer 3690
Alt is defined in the software to jump to the ACER E Technology software suite. If you have wiped the hard drive clean without saving a backup of the application, you are out of luck. If you saved an applications backup, then re-install the Etechnology software suite.
Oct 06, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
