Question about Denon Audio Players & Recorders
DENON D-M03 DISPLAY IS TOO DIM
I'VE AQUIRED THIS AUDIO AND THE DISPLAY IN THE BOTH UNITS IS VERY DIM.I HAVE LOTS OF REPAIR KNOWLEDGE BUT ON THIS ONE I AM NOT GETTING ANYWHERE.
( DENON D-M03 )
I have a 1997 Honda accord 4cylinder v Tec engine after a friend poorly installed a new stereo system the speedometer lights won't turn on I have to boost car evrrytime and it overheads and rear defrost...
you fried has done a lot wrong and has upset the electronc balance necessary to run the ECM program properly. It is no longer a matter of cutting in anywhere for power. Pull it out and repair any wires cut or spliced then take it to an authorised radio installer shop and have it fitted proprly.
with todays electronic controlled cars ,the best advice is to have the retailer fit the units for you as they have the experience and the tech knowledge to do the job
Feb 07, 2015 | 1997 Honda Accord
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
Dim display
The display may be available but can be very tricky to replace----the issue could also be the voltage source to the display is down or low and the display itself is ok.
Lastly I have seen two units where there was in the menu a setting for how bright the display is.......
To try to locate the part Google the model number with "parts" or "display" etc.
Dec 04, 2012 | Microwave Ovens
Javelin LC screens fading out to black. How can I fix them?
Most likely bad capacitors. They can be replaced but I wouldn't recommend a novice trying to do so. It requires soldering skills. If you can get into the monitors and check the inverter boards to see if any of the caps look like the ones in this video http://www.youtube.com/watch?v=oDGjWOabJ2E that would be a start. At least then you're armed with knowledge before getting overcharged by someone who wants to charge you a couple hundred bucks to replace a couple $4 caps.
Hope this helps.....
Feb 22, 2012 | Javelin Systems Inc Javelin LC PC Desktop
HITACHI 53FDX01BA THE PICTURE IS GETTING DIM. ALL THE COLORS LOOK GOOD EVERYTHING IS JUST GETTING DIM
This is a common problem on this Hitachi model. You can get the parts and repair instructions from www.TvRepairKits.com. In most cases the TV will look real dim or have no video...but audio will work,
Jul 18, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Can a CD player, Model CDC-80, manufactured in Jan., 1991, be reparied?
Ya mean Yamaha?
EVERYTHING can be repaired for a price but sometimes the cost exceeeds replacement.
There is NO pat answer to that question. it would all depend on what's wrong, parts needed and available, technicin knowledge....
There's a non-working $50 on eBay.
http://cgi.ebay.com/Yamaha-Model-No-CDC-80-Compact-Disc-Player-Changer-/200581920588?pt=LH_DefaultDomain_0&hash=item2eb39d374c
There are lots of comparable working units out there for about what a repair might cost.
Mar 12, 2011 | Yamaha Audio Players & Recorders
Display on clock fade out but if i cover it for a few min it come back up mod. jenair cook top sve87600b
I've often seen the display on these units go dim due to a failure in the control board. It may well start out as an intermittent failure. Your comment about covering it reminds me that some ovens have an ambient light sensor to automatically dim the display but I don't recall seeing that on your model.
In either case, it sounds like the classic failure mode we often see.
If you can have the control removed, we may be able to help you, we repair oven controllers at www.fixyourboard.com.
Best Regards,
Bruce
Oct 10, 2009 | Jenn-Air Cooktops
Radio display does not work
Honda has a problem with the PCB board in the radio, See your Honda dealer for repair info. Service bulletin 04-027 says:
"In some audio units, a component failure on the PCB
(printed circuit board) could cause the audio display to
become dark or dim, and prevent the audio/HVAC
panel buttons from illuminating.
To ensure that customers have adequate warranty
coverage for this potential problem, American Honda is
increasing the warranty on the audio unit display to
7 years or 100,000 miles, whichever occurs first. For
other defects the standard 3 years or 36,000 miles
warranty applies, whichever occurs first."
Feb 15, 2009 | 2004 Honda Accord
447 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
