Question about Waterway Clear Water 22" Sand Filter System with 15hp Pump 2 Speed
I bought a house this winter that had a pool and i have no idea how to set up the filter we tried to get the previous owners to show us when we bought the house but they were not very cooperative
  • 640 Answers
Here is a copy of the users manual for these pool filters. It has a detailed drawing of how the filter should be assembled and set up. Hope this helps!
http://www.backyardcitypools.com/images/bwp/carefree-manual.pdf
Posted on Mar 15, 2011
Closing inground pool
Question:
How do I close my pool for the season?
by Osko Pool n Spa Information
By following the provided instructions, you will be able to professionally close your pool for the winter season. Additionally, you will protect it from winters abuse and make opening it next season...simple.
Required Tools
a) Standard Screw Driver
b) Phillips Screw Driver
c) Ratchet Set
e) Plumber Pliers
f) Sump Pump
g) Extension Cord
h) Garden Hose
i) Five Gallon Bucket
j) Air Pump or Shop Vac
k) Pool Vac & Accessories
Required Chemicals
a) Pool Shock
b) Algecide
c) Chlorinating Tablets
Required Accessories
a) Winter Cover
b) Pool Pillows or Inner-tubes
c) Chlorine Float Dispenser
d) Water Bags (for ingrounds only)
Step One - Debris & Chemicals
Remove any debris from pool water by use of a leaf rake attachment.
Add the appropriate amount of shock treatment to the pool water, as prescribed on the packaging.
Add the appropriate amount of algecide to the pool water, as prescribed on the packaging.
Run your filter for the appropriate time to circulate all water once.
(see your filter documentation for your size pool)
Install your floating Dispenser and winterizing tablets.
Step Two - Vacuum & Water Level
Vacuum your pool while setting your filter to the "back wash" or "waste" setting.
(this will help lower your water level)
After vacuuming, install the sump pump and drain pool to about 6 inches below your thru-the-wall skimmer.
Step Three - Parts Dissassembly & Cleaning
Disconnect all ladders, filter systems, hoses, solar reels and/or other accessories.
Using standard household cleansers, thoroughly clean all ladders, solar reels and/or other accessories.
Dissassemble filtration system.
Remove sand, cartridge or DE powder from your filtration tank.
Thoroughly clean all filter system parts.
Allow all items to dry.
Store all items in an area that will not be subject to freezing temperatures.
Step Four - Pillow & Cover Installation
Inflate all pool pillows or inner-tubes.
Install one pillow for every 15' of linear water surface.
(example: a 15' x 30' would require at least two pillows)
Tie pillows to pool area via nylon rope and place equally with respects to pool walls and each other.
(this is extremely important! This prevents freeze damage)
Install winter cover as prescribed by the covers manufacturer.
Step Five - Winter Tips
During the winter months, remove any excess snow from the winter cover.
(If you have a solid cover, this will prevent excessive weight form tearing you cover)
(If you have a mesh cover, this will prevent excessive water build up)
Hey, Your Finished! Congratulations, you just saved money while doing a professional job
Nov 11, 2013 | Hayward SAND FILTER, PRO SERIES
Emerald spa jets
does the motor for the jets BUZZ ? most the time the motors will seize and, with the power off, you can use a screwdriver in the slot in the shaft of the back of the motor to get the motor turning again.
but it's a good idea to have the motor checked,
search your area for your local pool pump motor repair guy with FREE testing
let me know how it goes.
Jay
Jun 07, 2017 | Pool & Spa
How to hook up vacuum to sand filter
hooking up the vacuum assembly is done at the poolside skimmer. there is a vacuum plate that goes over top of the skimmer basket, allowing you to leave the basket in place to catch any larger debris. the plate will have a fitting at the top to attach the vacuum hose. before turning the pump on, be sure to bleed the air out of the vacuum hose so the pump does not run dry.
if this is a new thing for you (like you just bought the house with the pool, or something like that), please post any further questions in the comment section, i realize this can all be sort of overwhelming at first, and often the previous owners don't leave you all the pieces you need!
Aug 25, 2010 | Hayward SAND FILTER, PRO SERIES
How do you operate the whole house fan in order to save heat loss
make covers for garage opening with hinges open in summer close in winter .
Oct 07, 2009 | Heating & Cooling
I bought an Intex 15' x 42" above ground pool at a garage sale. No instruction or DVD were included. How is the skimmer set up?
Plug the inlet & suction openings with provided plugs
Hook up the hoses.
Release vent screw from the top of the filter housing.
Remove hose plugs.
Start pump
when water comes out filter housing vent - close it.
check for proper flow.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Waterway Clear Water 22" Sand Filter System with 15hp Pump  2 Speed Logo
131 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
