Question about Kitchen Ranges
Oven problem i have a roper wall oven model#B8756X1, was having a problem with the clock, the display would disappear and then when i slammed the oven dr the display would reappear. i changed the clock and i still have the same problem, but not as often. Any suggestions?
    Genius:
  • 1,073 Answers
Probaly not an issue with the clock but with a loose connection in the wiring to the clock, by slaming the door you are making up a connection, i wou ld check all connections at the clock and this should lead to the problem
Posted on Apr 10, 2008
My oven display has "sABBATH" written on the
May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
Apr 24, 2011 | Maytag 24" Built-In Single Electric Wall...
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 | Bosch Ovens
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
appear in the display.
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
Nov 29, 2010 | Frigidaire Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Model # arg7600ww. Display clock keeps flashing,
The eoc has gone bad. Clock control. You will need the manufacturers number also starts with a P when ordering this part. Hope this helps.
Mar 09, 2010 | Amana Kitchen Ranges
Have Roper LP Range model S8757. This is a self cleaning oven but takes forever. So I cleaned it myself and now oven won't light. Get F3 on display.
Your oven temperature sensor is bad and must be replaced.
It is inside the oven, a short metal piece extends into the oven. It is secured by a screw into the back wall of the oven.
Oct 12, 2009 | Roper FGP305 Gas Kitchen Range
Double oven (WW30430B) got the similar display dim/disappear prob
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Aug 23, 2009 | Jenn-Air JJW8530C Expressions Collection...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
