Question about Pegasus Technologies Pegasus Toilet Paper Holder Chrome With Sand Black
We have a pegasus towel rack and have lost the screw
That connects it to the wall. Where can we get another one.
  • 349 Answers
Towel rack fix came out from wall
Go to a hardware store and wall anchor screws to reinstall the brackets that hold to towel bar to the wall. There should be two brackets and two holes on each bracket. If the existing holes are to big, drill two new holes on each side. Screw the brackets to the wall. As you turn the screw, the will expand in the screw hole and hold the brackets that you attach the towel bar to.
Feb 02, 2018 | Towel Rack Home
I'm trying to install a Glacier Bay ceramic towel rack but the instructions are worthless. How does the metal mounting bracket attach to the wall? Does the indented part screw in and and the c
The indented bracket is attached to the wall with screws but should be left loose enogh to allow the ceramic part to slide down over it and seat.
Oct 05, 2014 | Home
How to remove Moen towel rack from wall?
I think for removing moen towel rack from the wall, you should hire a professional because your wall may get damaged if you do this work by yourself.
Apr 02, 2013 | Home
I have a wooden shelf which I want to hang above my flat screen tv, what type of screws should I be using?
Depending on weight of shelf and contents.
And if you can hit a wood stud.
http://t0.gstatic.com/images?q=tbn:ANd9GcRgImEAL3MOBqQus1-EOz1kKhcNhWnCFnVcBrQtBZaGw0KC_bdPCw
I like the plastic zip-it anchor because it is pretty strong for towel rack or shelf with a few books etc, It simply drills flush into the wall and then you can use a regular pan-head or drywall screw to connect shelf to zip it. Later the zip it can unscrew and hole is filled easily.
Wall dog is nice for 1 step into drywall. Lightweight shelf, with 2 small books and vase..
Toggle bolt for heavy shelves, But requires good sized 1/2" hole drilled first, and takes a few skill techniques.
Mar 13, 2013 | Woods Hardware & Accessories
Template for towel rack doesn't fasten support to wall.
Contact the manufacturer and explain the problem, if it's faulty part they will send you another one rather than you giving them a bad name or they may have a quick solution to your problem
Terry
Nov 25, 2012 | Home
How do you remove the eva towel rack holder
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
Trying to hang gatco channel towel bar. there are no studs what size hole should I drill? I lost my directions.
Go to Home Depot, hardware or Plumbing isle,, tell them you want to hang a towel bar and you want some self drilling wall studs rated larger than or equal to 10 pounds. bring one of the screws from your Towel bar kit.
Nov 28, 2010 | Gatco & Channel& Satin Nickel Towel Bar
Pegasus Estates 861 360L towel ring installation?
there is a groove on the top of rhe towel ring that the mount has an indentation that this groove sits in. The tiny screw pulls the groove into the mount in turn, holding the ring in place
Jul 14, 2009 | Waterstone 4055-ORB Oil Rubbed Bronze...
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Pegasus Technologies Pegasus Toilet Paper Holder Chrome With Sand Black Logo
117 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
