Question about Refrigerators
My Kenmore Coldspot Elite refrigerator will make ice but it will not feed the ice out of the door on either crushed or cubed ice setting I can hear a motor faintly turning but nothing is happening while I hold the dispenser button
    President:
  • 1,561 Answers
Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism.
If the fill tube in the ice maker itself becomes clogged with ice the unit. Locate the fill tube which is right above the cube tray. Use a hair dryer to unclog the tube. If the tube becomes clogged with ice again your dispenser valve is likely not closing between fills and water is dripping into the tube. You will need to replace the valve. To do this, first turn off the water, then remove the sheet metal backing of the unit by taking out any screws. Pull out the inlet hose and remove the dispenser valve to which the hose was attached. Put in a new valve, reattach the hose and backing, turn the water back on and your problems should be over.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
Take care.
Posted on Jun 05, 2010
  • rolypolysand Jun 07, 2010
    Thank you for your response, but the fill tube is working ok because the freezer has been making ice. It's just the dispenser that does not feed the ice out of the door that is the problem - the ice is there it just doesn't come out. I press the button and I can hear it faintly churning but nothing happens on either crushed or cubed ice settings.
  • Sulaimon Jimoh Olayemi Jun 07, 2010
    When your ice machine is making ice but not dispensing, check the ice
    maker's harvest cycle. The easiest way to do this is to get a small
    length of insulated wire, strip about a half-inch of insulation off of
    each end (use a wire cutter) and insert the ends into the test points on
    the ice maker marked "T" and "H." Make sure you use insulated wire to
    avoid a nasty shock. If the harvest cycle does not start, there is a
    problem with your ice maker's control module. If it starts but water
    doesn't flow into the ice maker at the end of the cycle, the fill tube
    may be plugged with ice.
      Fixing the Problem
    1. If it appears that the fill tube is clogged because no water is
      entering the ice maker, check the fill tube and remove any clogs.
      Unclogging a fill tube is a quick fix that should only take you 10 to 15
      minutes at the most.
      If the harvest cycle is not starting when you
      test it and you have a defective control module, it is possible to order
      a new one and install it yourself following detailed instructions
      available on the web. The Samurai Appliance Repair Man at Fixitnow.com
      is one of the best online resources, with clear diagrams and manuals
      available. For the novice do-it-yourselfer, this process might
      take you an hour or two.
    Take care.
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
My shaved ice won't work on my Kenmore Elite but all other options do
Be sure the metal bar under the ice bucket is fed into the 'stirrup' at the back of the freezer, if it is in place, hold the freezer light switch down while the door is open, and press the ice dispense paddle to observe auger operation and see if the 'stirrup' is pulled upward by the solenoid that operates it... Crushed Cubed Ice Solenoid WR62X23154
May 23, 2016 | Kenmore Refrigerators
It is a Kenmore Coldspot (Whirlpool) side by side model # 106.57024601 a repairman replaced the ice maker circuit board which had shorted from washing the outside of freezer door with spray cleaner....
its a tuff call but i think if the board has been replace and the motor runs then ck the touch panel that selects reg or crushed . . and if it is the board that has been replaced re ck all the connections .. mm
Sep 24, 2010 | Whirlpool Refrigerators
I have a kenmore elite model number 795. my ice dispencer only gives crushed ice even though its set to cube
1st i would remove all ice out of bin, clean outBIN with warm water under sink. put ice back in do not throw away for testing purposes. if worked then a cube may have been caught in bucket chopper improperly . if didnt change anything could be a bad crusher solenoid. in home service could run you 90-145 dollars depending where you live. if you do it yourself crusher dispenser solenoid will run about 30-50 DOLLARS. hope this helps
Sep 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
