Question about Nintendo Wii Console
My Wii won't turn on. My Wiimote only blinks and my Wii console doesn't have a power light. I tried plugging in and unpluging the Wii but nothing happens.
    Problem Solver:
  • 15 Answers
The wire.. i had this problem the wii power wire is screwy ... replace it and try .you can get it replaced where you bought it..
Posted on Jun 06, 2010
My wii will turn on, but nothing shows up on the screen
Good news i had same problem and what i found out was that the wii bricked up an easy fix is to unplug ur wii from all cables then after 3 minutes plug only the power cable and see if ur wiimote connects but before dat remove sd and usb if the wiimote connects but u getno display then u have t afjust ur screen resolution hope this helps :)
Jul 03, 2012 | Nintendo Wii Console
We tried to reset the sync buttons and the blue lights on the remote blink repeatedly but it still does not communicate with the game
Try removing and reinstalling the batteries from the wiimote and the unplug the wii power cord at the outlet end for a couple minutes. I had that problem once and this seemed to fix it.
Mar 07, 2011 | Nintendo Wii Console
My wii game will not turn on
Unplug it from the back of the Wii as well as the outlet for 3 minutes. Perhaps a surge during a storm...that's what happened to mine and it came right back on after I unplugged it for a few minutes.
Jul 20, 2010 | Nintendo Wii Console
I have my console plugged in.. and it worked just a few days ago. but now the lights wont even turn on.. HELP!
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of yourwiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
Jun 21, 2010 | Nintendo Wii Console
Wii console is not responding
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
Jun 18, 2010 | Nintendo Wii Console
Wii wont turn on
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that dosent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
May 20, 2010 | Nintendo Wii Console
Wii will not power on. Light is off.
Try the Wii "reset" procedure.
1. Unplug the Wii for at least 5 minutes.
2. Plug the Wii back in.
If you have the yellow light, turn on the Wii using the Wiimote.
Jun 09, 2009 | Nintendo Wii Console
REMOTES AREN'T CONNECTING TO WII CONSOLE
Try this:
Turn off your wii and unplug it.
Wait a few seconds and plug it and turn it on.
Open the cover in fron of the wii and push the red button for a few seconds.
Now take the lid off the back of your wiimote and below the batteries there is a red button, press it and the leds that indicate what number player you are should start blnking.
Press the red button on the wii again and now the light in the wiimote should stay on.
Test your wiimote.
Mar 17, 2009 | Nintendo Wii Console
Wii remote won't work. Just lights up
pair the wiimote with the wii. open the slot where the sd card goes press the red button then open the wiimote and press the red button right after
Feb 25, 2008 | Nintendo Wii Console
Remotes
When the lights are blinking like that, it's indicating the battery level, and also indicates that the wiimote is not connected to the wii. Replace the batteries in the one with the left light blinking and see what happens. Try turning off the wii, and pressing the power button on one of the wiimotes. It should turn on the wii and then the far left light will turn solid. Then press a button on the second wiimote and it should connect. If it doesn't, press home on the first wiimote, go to the settings at the bottom, and click Reconnect. Then follow the onscreen instructions and the problem should be solved. Note: my account name is supposed to be ryanriopel28..
Aug 09, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
186 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
