I get error code 651 when I try to use the internet
  • 560 Answers
Hi. There are lots of possible problems that are causing error 651.
Let's start with Virtual PC. Please see if you have Virtual PC 2007 or MS Virtual PC 2007, if you see one, uninstall the program and re-start your computer then try to dial-up. Let me know the result.
NOTE: Rename your raspppoe_orig.sys back to raspppoe.sys we will deal with that later.
Posted on Jun 05, 2010
  • Liza Halbrook
    Liza Halbrook Jun 05, 2010
    If the previous solution did not work, click here and follow instruction under METHOD 4. Save the instructions first and delete unnecessary dial-up connection.
    Error 651 is a bug on Windows 7 and Microsoft don't have hotfix for it yet.
    Scholar:
  • 96 Answers
Hi, you can use this link for referrence. Click Here
3 Suggested Answers
SOURCE: I cannot access the internet
http://www.talktalk.co.uk/help/broadband/error_651.html
VPN or Dial-Up Error code 651 - Your modem (or other connecting device) has reported an error.
Posted on Jun 06, 2010
  • 1768 Answers
SOURCE: Error 651 appears when I
Your user name or password is incorrect.
Try typing it in a word pad or notepad first to see if you have it typed correctly.
Posted on Jun 11, 2010
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
N600 error 651
This is not a router, it is a range extender. It does not work without a router connected to the internet.
651 is just a timeout, as it cannot get an internet connection.
Look at the router and find out why the range extender does not work.
Does the router work on the internet, try wirelessly and by directly connecting a cable into the LAN port.
Mar 12, 2014 | NetGear Computers & Internet
When I try to connect my laptop to the internet I get broadband (PPPoE) which requires a username and password?
Reset your wireless device to default settings and reconfigure the SSID and Security Key.
Mar 28, 2013 | Gateway NE56R10u Laptop
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Gateway dx4720-03 error 651 can't connect to internet
hello,
This error"Error 651" is caused by this file raspppoe.sys you can find it in c:/windows/system32/drivers/ rename it(raspppoe_something.sys) and copy the new file from a friend pc that runs vista .
Jun 10, 2012 | Gateway Computers & Internet
What is error code 651?
I have fixed mind through following steps, OS Windows 7. This works if you can still use cable internet, so that system can download the driver.
In my case there was no wifi utility, no connections detecting, no bars IIII.
Solution:
Please note it is mostly to do with your network drivers, if you go to device manager under the network adapters, you will see network controller marked in yellow. Dont worry.
To make your wifi connection work please complete the following steps:
Goto:
Device manager > trouble shooting ( column 3 , second last row )
Now under " Hardware and Sounds" heading go to configure a device.
It will start trouble shooting automatically, and try to download and install the right network control driver.
My system is using: Realtek PCIe FE Family Controller and after downloading the driver. I have now following installed.
Realtek RTL8191 SE802.11 b/g/n Wifi Adapter ( this was missing )
Now when I go back to device manager I have both are functioning and after reboot I automatically connect to the wifi. So everything is fine.
So my advice to all whatever make is your PC / OS , do go to device manager and try trouble shooting.
For those who have found this solution helpful, please email me: manny.nlAThotmail.com
Jan 21, 2011 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
379 people viewed this question
David Payne
David Payne
