Question about Kenmore Oasis HE 27082 Top Load Washer
Thanks to everyone who told me about the recall/upgrade. I just called Sears and they are sending out the control panel and someone will install it. They NEVER sent me a letter! Thanks so much. This F1 has been driving me CRAZY!!
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 18, 2010
Machine cycles through heavy to light loads continually
I have the Oasis HE 27082604 and have been having the same problem as everyone else is. I called Sears and other numbers and they said it was beyond their control and this washer wasnt recalled. So they wouldnt honor it. Does anyone have a recall number. They say there is no recall on these washers.
Mar 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 error message comes on every time I start our washer after lid lock engages!
THE PRINTED CIRCUIT BOARD IS BAD. DO NOT BLAME SEARS FOR THIS I SHOULD OF HAD A SURGE PROCTECTOR ON THE MACHINE. THIS may cost you like $250
Oct 03, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Dryer control panel works then suddenly doesnt. Same issue as everyone else this unit should be RECALLED. unplug it for 24 hrs and it'll work again for a short while. COntrol panel works then doesnt or...
I had the same problem only 1.5 yrs after i bought it. I called sears and complained till i got them to send someone for free to fix it. It had a bad circuit board and another part that cost close to $500 for them both. Was able to get a warrenty for $150 i think and it covered the parts.
Nov 21, 2009 | Kenmore Elite HE4 Electric Dryer
Piece if **** washing machine and dryer kenmore elite oasis
I called sears recall dept 1 888-548- 1509 told to make a service call about F problem and if that is the cause your charge for service call will be refunded and a new control board installed at known charge.The 27082 is not on the recall list yet but sears is aware of this condition.Don't give up just keep calling and ask that a copy of your call and complaint be forward to your address ,sears receives numerous call's each day about F1 control boards.
Cal them your self now and see if they will do this repair 1 888-548- 1509
Please leave a rating !
Sep 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
I have the same problem... could you send me instructions, too?
Okay...Fixya discourages us from having direct contact with customers outside the realm of this website, so I hope you will accept my reply in this forum.
If you are talking about replacing the operator interface board, its very simple. Just follow these steps:
1. UNPLUG the washer.
2. Remove the three screws in the back of the console.
3. With the screws loosened, the console will come of by lifting from the back first. Use care not to damage the small wire harness under the console.
4. Remove the wire harness from the User Interface board and remove the knob (by pulling) from the front panel. Lay the entire control panel face down on a soft surface (like a stack of towels).
5. Carefully remove the white plastic cover plate that is installed over the control board.
6. Once the cover is removed, carefully remove the old interface board by prying gently on the series of tabs around the perimeter of the board. There may also be some mounting screws to remove as well.
7. With the old board removed, carefully install the new board by inserting the control knob shaft through the hole first. Then, gently snap the board in place, making sure all the tabs around the perimeter of the board are in place. Reinstall any small mounting screws. NOTE: Do not handle the surface of the board with your hands. Handle the edges only, to avoid electrostatic discharge from your body causing damage to the board.
8. Reinstall the protective plastic white cover over the interface board.
9. Flip the console upright and reinstall the wiring harness and control knob (The knob only goes on one way).
10. Carefully insert the console in the front grooves on top of the washer, first. Then lower the back and reinstall the screws.
The repair is pretty straight forward. However, if you have questions, please post back and let me know. I hope this helps you.
Now...it was recently brought to my attention by a consumer on this website that there is a recall on this circuit board. The following paragraph is the direct direct quote:
"I too had the misfortune of dealing with the continuous beeping on my washer (model # 110.27062600). No code was given.I called the Sears hotline and asked for the manufacturers warranty department. I then called the recall line at (800)659-7026 and after giving my model number and serial number they discovered is was indeed recalled or being "upgraded"! They have ordered the part and are sending someone out. For those who have already paid to have it repaired I would call Sears and ask for a refund. Good luck!"
-joycdex
If I understand this correctly, you may not have to purchase a new control board. Or, if you did, Sears may refund the cost and provide someone to install it for you. It may be worth your while to contact them to find out. I hope all this information is helpful to you.
Aug 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Control panel lighs blink and ice door opens and shuts. The fridge and freezer is still cold. I called Maytag and they are sending me a new circuit board. The local Maytag store owner told me to...
i just called Maytag (now Whirlpool) @1-800-253-1301.  They are shipping me a free control panel and are also paying for a certified installer to come to my home to do the exchange.
I told them when I called that I learned from the internet that it was a quality issue and they did not disagree.  They processed the order and offered the installation without me asking.
My refrigerator is out of warranty so they covered it as a quality issue.  We enjoy our refrigerator and have not had any other problems accept when we first received it and someone had to come and adjust the icemaker.  Yes the icemaker is small by some standards but it meets our needs. When we need lots of ice, for guests we just buy a bag for less than a buck.
Great service response from Maytag.  Thanks.
Aug 01, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Recall on kenmore oasis
I have one of the first kenmore oasis and I get the F1 and off balance error all the time I called the recall number line is 1 (800) 659 7026 they said that they are doing a free upgrade to replace the control board the only problem is the board is on a back order and it may take a week to get the part in.
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis washer
Jan 06, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE top load washing machine F1 code
Ok so you will all love this answer. Not only do I own this set but I also sell them at sears in des moines, ia. Ok so there was a recall on the controll boards it's fine don't be scared all you have to do is call 1800-659-7026 give them your info and model and ser.# they will then send someone out to replace the control board it takes about ten min for all of it and it is all free no matter when you bought it. But in mean time quick fix for all of you is to unplug the washer then hit power then stop over and over tell there is no power left in it then plug it back in and it will work fine for awhile you may have to repeat if it does it again. But after they come out it will work fine. yes this has happened to me it sucks it took two years to find out what was wrong they didn't even tell us I had to ask alot of parts guys and look it all up. So for everyone that this is happening to I'm sorry I just hope this gets out to all of you because I work very hard to know my product and take care of my customers ask any of them and it's not easy working STRAIGHT commission and people don't want to come back for these kind of things. But remember the reason why you came there in the first place we will give you the lowest prices in town and we know what we are talking about, well most do if not they ask me:) so I realy hope this helps someone out there.
Dec 12, 2007 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code on Kenmore Oasis He
After getting the F1 error on my model 110.27086601 and looking at other posts here & elsewhere, I made one call to the "Product Resolution Center" at 800-847-9083 on 4/9/10. They answered quickly, looked up the model & serial number I gave them (begins with CT18) and confirmed that the unit is covered under the "upgrade plan" (as opposed to calling it a recall). They are sending the part directly to me today and they scheduled a Sears tech to come install it in 10 days (or less if the part arrives sooner). The part, shipping and service call are free. The whole call took less than 5 minutes and was no more difficult than ordering a pizza. The agent was polite, professional and a pleasure to deal with.
I'm pleased that 2 years after the warranty expired they are providing this repair free of charge and without any hassle.
To those who have had problems when calling or who will be calling, may I offer this tidbit for dealing with any customer service contact? Be polite and businesslike. The agent on the other end doesn't need to hear about "how disappointed you are, blah, blah" or that you've "been a loyal customer for 84 years" and you've "never had a problem like this" or any other editorial commentary - just be friendly, and say something like " Hi, I have an Oasis washer with the F1 problem and I understand that there's a recall covering this." That's exactly what I said and the agent efficiently handled everything from there.
Remember, the agent gets measured on the number of calls they complete so they just want to take care of you as quickly as possible. Help them by just simply stating the problem and just answering their questions with just the information requested. They are not there to listen to people whine - they've heard everything you have to say a thousand times and they will appreciate your brevity and no nonsense demeanor. Make it easy for them and they'll make it easy for you. Do your venting here if you must.
Dec 06, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
71 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
