Question about Samsung L200 Digital Camera
My samsung pl50 won't turn on it just bleeps at me when i try and the shutter is stuck out. it was working fine when i was taking pics of my sister then it just shut down n won't turn back on
I've sent back 2 phones with this exact problem. Came on here and found the solution on the blog from another camera. It works! Here it is:
Figured it out....the zoom lense, while in the open position, was a little out of line, thus preventing the camera from retracting it. After gently re-aligning the lense, it retracted properly and the camera resumed normal functioning.
So basically, wiggle the lens every so slightly then try the power button again. Hope it works for you!
Posted on Jul 01, 2010
  • megans364 Dec 20, 2010
    Thank you so much!! I came on here with the exact same problem with the exact same camera.Gave it a wiggle and it worked! I thought I was going nuts as have been charging my camera for about two days.Thanks for your advice :-)
My samsung PL50 camera: i havent used my camera in a while but i bought a new charger, it is full charged and i can browse the pictures, but as soon as i press the on button the lense trys to move but will...
OK, the lens assembly has failed causing a shutdown error. So, technically, the camera is trash because it would WAY more expensive to fix that one than to just buy a new one. NOW, read carefully. When you power on the camera, watch when the lens tries to come out. You'll notice that the shutter on the lens opens first then it pokes out a bit then goes back in and shuts down. If you time it right, you can slip your fingernail under where the shutter is and "assist" the lens out more. dont pull too hard because you'll rip the fron of the lens assembly off. but once it is able to go past this point, 9 times out of 10, it fixes the problem entirely and the camera works just fine after that.
Aug 09, 2012 | Samsung Pl50 10.2mp Digital Camera Black...
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
When turned on just shows black screen. Used to be able to pwer off and back on and would work. Lens issue? Can view pics on memory card just can't take pics anymore.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 14, 2011 | Canon PowerShot S2 IS Digital Camera
My samsung BL103 camera takes good pics inside but ot outside. how do i fix
First make sure that you are in "Automatic" mode, and not in one of the camera's othe manual modes which may keep the shutter open for an extended period. But if you are indeed in auto mode, and it's still doing this, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 09, 2011 | Samsung BL103 Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
I have a Kodak EasyShare M340 it was working fine earlier today but now when I turn it on the screen is black and when I take a picture it comes out black too, even with flash I can see the saved pics on...
Nov 20, 2010 | Kodak EASYSHARE M340 Digital Camera
Samsung PL 50 lens stuck half way
mechnism of the lens is deffective,get it serviced.
Mar 29, 2010 | Samsung PL 70 SL720 Digital Camera
Samsung pl50 camera - lense wont go back in and wont turn on
The problem with mine was that the lens motor was somehow stuck. I gently pulled the lens out as I turned the camera on. It went back to normal afterward. Hope this helps
Feb 01, 2010 | Samsung PL 70 SL720 Digital Camera
My cannon s21s has a blank screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 20, 2009 | Canon Cameras
Samsung L200 Digital Camera Logo
1,145 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
