Question about HP PSC 1610 All-In-One Printer, Scanner and Copier
Cartridge jam I was trying to print and I kept getting an error message that there was no paper in the printer even though there was. I did everything the manuel says to do and that didn't solve the problem. I got frustrated and turned the printer off and left for a while. I came back to try again and now I get a different error message...cartridge jam but there is no jam. I even tried scanning a document but it was illegible. I have had this printer for 4 years so maybe it's time to buy a new one. I would much rather keep this one if it isn't to expensive to fix. HELP ME!!!!!!!!!!
  • mustangCathy Jun 07, 2010
    I tried everything that was listed and nothing worked. I haven't decided if I should try and have it repaired, if that is possible, or just purchase a new printer. Thanks for the help!
    Brigadier General:
  • 3,513 Answers
Thanks for writing to Fixya.com.
Please find the steps which work normally if there is no major damage done to the printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00854650&cc=us&lc=en&dlc=en&product=1156652
If this does not work then there is a circuitry problem and I would recommend that you go for a new one.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Jun 07, 2010
Will not copy
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
Apr 20, 2013 | HP Officejet 7210 All-In-One InkJet...
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
My HP M1319f fax machine diplays a "No Print Cartridge" error.
I have checked for paper jam, remove the paper and cartridge was recognized.
Mar 02, 2010 | HP Laserjet M1319F Laser Multifunction...
Printed 47 pages, paper for page 48 started to feed incorrectly & was yanked out. However, LCD keeps saying paper jam even though entire paper was retrieved. Turning machine off, on, examined for any...
More likely especially if the paper was pulled out backwards, that the paper sensor just before the platen roller is bent or broken. When you pull paper back up thru the feeder it gets caught on this sensor tab and it gets bent, holding it up just like a paper scrap would. If it's broken or you can't locate it to bend it straight, you will need a shop to repair your printer.
Dec 31, 2009 | Canon PIXMA MX310 All-In-One Printer
I am also getting the "printer jam clear paper path" message
Check paper sensors in the paper path may one of them the shutter is stack.Ensure that the are free and in position.
Aug 22, 2009 | HP LaserJet 3015 All-In-One Printer
Cannot printer... it keeps giving me out of paper error, even when there's paper in the tray.
Sir,
Try these steps it may be solve your problem...
Step 1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2. Turn off the printer.
Step 3. Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7. If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step 8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks
Good Luck
Aug 04, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam 11
Step1
Step
Step
Step
Step
5
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
Step
8
Step
9
Nov 07, 2008 | Copystar CS-1815 Printer
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
No print catridge
The solution above worked on my printer, without power cycling.
1. Remove all paper from the input tray.
2. Open and close the door.
3. Reinsert the paper into the input tray.
Thanks,
Ilyas
Nov 14, 2007 | HP LaserJet 3050 All-In-One Printer
Epson stylus R 310 "general error" message
Those generic refills are not worth i, plus they may void the warranty. Try removing them and cleaning the little circuit board sensor. Make sure leaked ink hasnt covered them.
Oct 22, 2007 | Epson Stylus 1000 InkJet Printer
20 people viewed this question
Seeker5211
Seeker5211
