Question about Garden
John Deere L2 150\r\ntractor is running hig or
John Deere L2 150 tractor is running high or fast even in the turtle speed
    Scholar:
  • 141 Answers
Check to see if return spring has broke or came off.
If just stuck sometimes a little wd-40 goes a long ways.
Posted on Jun 06, 2010
John deere la175 deck blades spin quit and fast. hook up to pto and engage engine boggs and tries to die
Maybe the travel speed is too high for it or the fusible link in starting circuit is blown.Check and adjust timing belt tension if necessary.Visit john deere expert or dealer.
Jul 21, 2016 | John Deere Garden
1981 John Deere 1050 Diesel Tractor - Engine will go to high idle by itself. You can shut key off and engine will eventually die. What would cause the engine to high idle? Afraid engine will lock up.
There are 2 types of governors on diesels. one is controlled from the foot and is fixed speed at the foot setting. The other is variable speed which will run to high idle if the setting is not changed IE on start it will idle ok but if you use a fast setting on a hand throttle say to warm up the motor it will run to high idle. I suggest that if you have not had a problem before then you should have a diesel pump specialist look at it as there may be a fault in the governor control.
Jun 23, 2013 | John Deere Tractor Side Screen...
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
My sons john deere tractor only has one speed and reverse.
did you remove the high speed lockout? its the red thing on the shifter switch
Sep 06, 2012 | Peg Perego John Deere Turf Tractor
How do I shift my John Deere 420 garden tractor from high to low speed? I can't budge the shifter. Is there a trick to it?
With engine not running,pull lever towards rear of machine then move from one side to the other.If this does not work your linkage is locked up externally.
Jun 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a John Deere X304 that mows unevenly.
Make sure that your gauge wheels are not running on the ground during mowing,they should only hit the ground when you engage a high spot on one side.also when you level the deck the front should be a 1/2" lower than the rear.
May 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Peg Perego John Deere tractor 12volt will only work in reverse. Will not go forward in the slow or fast speeds
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Aug 16, 2009 | Peg Perego John Deere Turf Tractor
Battery lite glows when pto is engaged after running for 5min
The charging circuits used on smaller tractors are generally barely adequate for the load presented to them, so it is important that the tractor engine is running fast enough especially when using PTO power. If your tractor has a tachometer on it, JD has an indication of the motor speed you should use when using the PTO. If not, it is generally pretty close to max. It should sound like it is running smoothly although fast, and not with whining or rough sounds from the engine.
Apr 30, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
