Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Picture is not centered
Panasonic plasma tv model pt43c14. Installed a new lamp and now the picture is not centered. High def channels are fine.
SOURCE: high def tv: We replaced the lamp unit, but don't know how to reset hour meter
turn the TV power on the projection display or remote control.while pressing the volume button on the projection display hold down the PIP or split button on the remote control simultaneoulsy for more than 5 seconds.
Posted on Dec 31, 2007
SOURCE: We just replaced the lamp on our panasonic model
GO to the TV menu and try fixing the image from there
Posted on Aug 25, 2009
  • 17 Answers
SOURCE: Installing a Panasonic lamp for model number PT43LC14
You have two ways, you can call Technical Support, 1-800-211-7262, they should still be assisting with this, or the process is listed on pages 80-82 in the Operating Instructions, if you do not have the OI, here is a link to the PDF.
http://service.us.panasonic.com/OPERMANPDF/PT43LC14.PDF
Posted on Sep 23, 2009
  • 8457 Answers
SOURCE: installed a comcast digital box on the panasonic tv and
Go in menu goto setup pick ch.setup pick cable rescan all channels
Posted on Jan 13, 2010
Testimonial: "Seems obvious, but I did not think of it - thanks for getting it right, worked first time! Made me a hero with the family! Thanks!! D"
pabloloco
  • 2335 Answers
SOURCE: split screen
Yes I get the same problem with my Sony XBR and its Pace PVR.
The problem seems related to using HDMI interconnects; viewing the PVR through component leads allows the TV to switch modes easily, otherwise I have to turn the tv off and then back on again.
Posted on Apr 15, 2010
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Picture problem on Panasonic Plasma tv
Mar 11, 2014 | Audio Players & Recorders
How do I connect the DVD player to a Panasonic High Def Plasma TV?
Choose connections on the Panasonic that match those on the player--
Do you have on the player Component outs(blue,green,red and 2 audio which are red and white? This ought to give you the best picture and sound.
Other inputs to the set must match the ones coming from the player--Most owner manuals have a lot of details here.
If the player has 1080 output hook to a similar input on the set.
Some advice here: make the connections between units with both turned off.
Apr 03, 2012 | Durabrand DVD-1002 DVD Player
Hdmi on tv loses signal
Try another HDMI input on your set and see what happens.
Jul 26, 2017 | Panasonic Viera TH-50PZ80U Plasma TV
VIEWSONIC VPW425 42' PLASMA SOUND FADES ALL THE WAY OFF
I have a brand new Panasonic 42" tv, once in a while the sound fades out and then fades back in right away. I have it hooked up to a high def cable box with high def cable.
Jan 16, 2009 | ViewSonic VPW425 42 in. Plasma HDTV
Picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
Nov 17, 2008 | Hitachi 53SWX10B 53" Rear Projection...
High Definition Channels leave bar on top and bottom
More then likely it has to do with the aspect ratio of what you're trying to watch. Most DVD's are in widescreen format (2.40 to 1) like you would see in a theater but an HD tv is a 16 by 9 format or 1.85 to 1. Look at the DVD case and see. Also some HD shows are in widescreen so you'll get the same thing. You're only option to fill the screen is get movies in 1.85 to 1 or use your zoom functions however these do tend to distort the picture.
Feb 17, 2008 | LG 50PX4DR 50 in. Plasma TV
Low def pictures on high def flat panel
do you have your video pluged in to the tv or any thing elc if so unplug the video any see if that work or it could be your ampifier let me know how you get on thanks
Jan 03, 2008 | Panasonic TH-50PHD8UK 50 in. Plasma...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
