Question about LG LWHD1800R Wall/Window Air Conditioner
LG LWHD 1800RY6 Window Air conditioner owners manual
LG LWHD 1800RY6 Window Air conditioner - I have the unit but it was removed from the windown during winter and now I want to install it again but without the owners manual I don't know how to attach the brackets to install the unit.
SOURCE: LG BG8000ER Air Conditioner Problem!!
go to ca.lgservice.com find find owner's manuals under quick links and then fill in your product information to obtain a copy of the instruction manual.
Posted on Aug 01, 2007
ACTECH
  • 80 Answers
SOURCE: LG LWHD 1200 HR Air/Heater fan will not start.
may be a bad fan motor or loose wire, however some units have dip switch settings on the circuit board preventing the fan from coming on.
Posted on Dec 19, 2007
  • 958 Answers
SOURCE: Window air conditioner storage
sure you can but you have to prepare it for the winter.
re-oil the fan motor and make sure you wrap the whole unit up with a plastic wrapper just like the one used in the kitchen, the one that you can stretch to cover a whole stainless food container. then put it in a box to further keep the moisture away.
then after the winter and you want to use it again,
unpack it and inspect the fan motor. make sure that it is freely moving without binding or sticking.
let it stand for a couple of hours so that if there is dew inside , it would evaporate first .
then you can use it again.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 15 Answers
SOURCE: LG AIR CONDITIONER NOISE
What kind of air conditioner is this? A window unit or a split?
Posted on Sep 19, 2008
boysor2933
  • 293 Answers
SOURCE: LG LWHD8000RY6 Air Conditioner Not Cooling Room
Remove the front cover of the unit to expose the cooling coil. Put the unit on and observe if there will be formation of frost (ice) on the coil. If there's frost formation, the common cause is dirty cooling coil. Have it cleaned using an alkali base coil cleaner. If the coil is clean, then the problem is the fan motor. It might be turning slow due to copper loss. Have it replaced.
Posted on May 29, 2009
LG ac with heat model lwhd 1200 hry7 has power to it, cord reset, but nothing comes on, compressor or fan
Hello, Here is a trouble shooting guide for you and some details of how to fix it based on your symptoms. Here is a link to go to and make sure you jump around the site, it will tell you the fix based on your problem off the trouble shooting table. Link is below , copy and paste in browser. If this helped you, please rate it and some kind words are nice. Thanks Mike
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
Oct 12, 2011 | LG Heat cool Window Air Conditioner
My air conditionner is not working properly. It sends cool aire keep getting code E3 What can I do to fix it Tks
micheline, according to the LG Owner's Manual for the Model Number you listed, there is no LED display on the casement window unit (please see the Owner's Manual link below). How are you getting an E3 error code? Or by chance, did you list the wrong model number? Even Goldstar, that is made by LG, doesn't show your model number.
Please advise. Thanks.
Jun 01, 2011 | Goldstar LG LC1200 Casement Air...
AC unit LWHD 1800R won't turn on & test/reset does not respond.
Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
Jul 05, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
Do you have to add water to the air conditioner?
NO
if its an air conditioner not humidifier etc, then no!
it will create condensation which can mislead people into thinking it has a leak, this is normal. it is only moisture taken from the air we are cooling
cheers
Jul 05, 2010 | LG Goldstar GWHD5000 wall/window Air...
We have an LG model #LWHD-1200HRY. The air is
is it a heater also if so electric/or heatpump.
Jan 15, 2010 | LG Heat cool Window Air Conditioner
My LG LWHD 7000 is not heating.
heater coil located behing the front evaporator coil has burnt out. To access the coil you need to remove the a/c from its sleeve and the coil is located between the evaporator coil and the fan motor. An appliance parts house will have the replacement coil if you do it yourself.
Good Luck on your repair hope this helped
Dave
Jan 07, 2010 | LG Heat cool Window Air Conditioner
I HAVE MISLAID REMOTE CONTROL INSTRUCTIONS TO CHANGE FACILITY REQUIRED IE COOL, OR HEAT
You can download the owners manual; here is the link for it.
http://www.generalmanual.com/Air-Conditioners/LG-LA121CNP-Art-Cool-Air-Conditioner.htm
when you get to the page scroll down and you will see Download Now and under that "Owners Manual" just click on it.
I hope it helps.
May 27, 2009 | LG Art Cool LA121CNP wall/window Air...
LWHD1200HR - LG 12000 BTU Heat / Cool Window Air Conditioner
i have a lg lwhd 1200hr window ac the heating system dont work . it blow cold air out not heat. can you help me
May 28, 2008 | LG Heat cool Window Air Conditioner
Hi. Just bought a new in box "LP" LWHD 1200R window air conditioner. When I went to turn it on, I got an awful loud fluttering noise coming from the front of the unit. NOT the "slinger...
Hello Eric,
Let me see if this will be of any help take the front cover off and check to see if any packing material has fallen down in the air baffle. this will be towards the top of the unit on the inside. Also check to make sure that any insulation seems to be in place.
May 27, 2008 | LG Heating & Cooling
Dec 19, 2007 | LG BG8000ER Air Conditioner
Heating & Cooling Logo
307 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
