Question about Toro Lawn Mower With Toro Power Tools
How do i repace an ignition coil on a toro
How do i replace an ignition coil on a toro lev120, tecumseh engine, 362003A
3 Suggested Answers
  • 85 Answers
SOURCE: BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER
If you had replaced the flywheel key & did not engage the saftey bail it would brake the brake. Make sure the bail is engaged befor installing the flywheel.
Posted on Sep 24, 2009
bbreton
  • 437 Answers
SOURCE: need replacement engine or short block for
Tecumseh has gone bankrupt so finding parts and engines has been difficult. i would see if i could find a B&S engine with the same bolt pattern to mount on the deck.
Posted on Sep 30, 2009
No spark in my toro 38080 mod# snowblower,new plus,new gas ,fuel line,primer bulb,line, no spark
The Toro 38080 was made from 1979 - 1993.
With it not producing a spark then you have an ignition system problem. Depending which Tecumseh HM80 engine setup you have you may have either an internal ignition system or external. By this I mean under the flywheel or external to the flywheel. There was also hybrid system that was both internal and external.
This engine could either points based system or a CDI all in one coil pack.
Now if it is an internal points systems it will be major an under taking for someone that never worked on one these engines as if you replace the points the ignition system must be re-timed. Note that where a few fix time setups. You might get lucky and it just dirty contacts which can cleaned without up setting the timing. To gain access to these points the flywheel must be removed.
Probably the best to do first is to download a copy of the service manual to see if this something that you can do or if you what to get a small engine mechanic that is experienced with Tecumseh repair to do.
Ignition system info starts on PDF page 67 (manual page 63) in the following manual. It will explain on how to test and repair the systems involved.
TECUMSEH-SERVICE--REPAIR-MANUAL-3HP-TO-11HP-4-CYCLE-L-HEAD-FLAT-HEAD-ENGINES-.pdf
Dec 27, 2014 | Toro Garden
Tecumseh lev120 - Toro lawn 6.5 GTS - Clean bolt, new gas, new oil, new pull cord - Cord pulls back on you - I read that it is the flywheel key - I pull the cover off and the key looks in place - any
You really need to remove the flywheel to check the key, the only other reason for it to kick on the starter rope is if the blade bolt is not tight enough.
May 23, 2013 | Garden
Need carb linkage diagram for tecumseh LEV120 engine
yes or a bad safty switch check the seat the brake and the clucth
May 07, 2013 | Garden
TORO RECYCLER LAWN MOWER MODEL 20017 2006 EDITION
to far away for me to look at it i'm on the east coast
Sep 01, 2012 | Toro Garden
I have a Toro super recycler model 20017 with a tecumseh motor, model LEV120, spec 361541B has spark and is getting fuel but will not start any suggestions? Have already replaced coil cause previously had...
Make sure that the doggone brass bolt that holds the carb bowl on was cleaned as well. It is the main jet and has tiny holes that get clogged from evaporated fuel/varnish and debris (if no inline fuel filter is used). It has holes on the bottom and the smooth part of the sides...it needs to be clean and shiny! If all is well and the motor is an OHV, then maybe the valves need adjusting.
Sep 14, 2010 | Toro Super Recycler Super Bagger Lawn...
I replaced ignition coil on a Tecumseh Toro 20018 mower. It would not start without disconnecting green "kill" wire. Now what do I need to do - replace the kill switch? Is the kill switch located on the...
It is a short in the kill switch, or the wire running to the kill switch. check insulation on the wire running to the kill switch and check the routing of the wire to insure that it is not being rubbed by moving parts, or the insulation melted by hot engine parts such as the exhaust system. Finally check that the kill switch itself is functioning properly with a test light or OHM Meter.
Aug 12, 2010 | Toro Garden
Need replacement engine or short block for Tecumseh LEV120-361541B
Sep 30, 2009 | Toro Lawn Mower With Toro Power Tools
BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER THE ENGINE IS A TECUMSEH MODEL lev120 SPEC 361541b 195cc
Sep 23, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
439 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
