Question about Samsung LN-T4665F 46 in. LCD Television
Samsung lcd ln46a550pf3 no sound from hdtv reciever
Just bought this samsung lcd with a ps3. works fine with the ps3 and hdmi cable. signed up for comcast hd and connected via hdmi-dvi and got picture, but very poor sound via red/white audio cables. tv sound is very faint, but accompanied by loud high piched buzzing/humming. also tried connecting through component cable (red/blue/green) with red/white audio cable but ended with same result; also, hd box works fine when connected with regular "screw-in" cable (although regular tv quality and sound). also tried changing to new red/white audio cable, but didnt work. anyone help? new box maybe?
  • 1 more comment
  • Anonymous Sep 05, 2008
    standard cable on cable hd box worked lousy picture and sound. tried a DVI to hdmi connection to tv-picture better but no sound (did you rca cable out to in.
  • Anonymous Mar 22, 2014
    There are only two connectors on VCR one red one white no yellow so what sort of cable would I need to get me connected to use my videos
  • Anonymous Mar 26, 2014
    TV is Sharp Aquos LC80LE844U. All cables are High-speed HDMI. Cable box connects via HDMI to Marantz SR5006 amp - amp to TV via HDMI. TV Aquos Link is ON and ARC is set to Auto. Was working fine for over a year. Now intermittent problem will lost ability to adjut volume. TV partially responds in the I get the words Aquos audio and the speaker icon but no progress bar or volume number. When this happens, the adjust volume on the cable remote, TV remote, and TV volume control all produce the same result. The display of the speaker icon confirms that the TV recognizes the attempt, but the volume does not respond or show the progress bar. Have replaced remote gatteries, the HDMI cable from the amp to TV, have tried turning off and back on amp and TV - nothing works. Also intermittent - turning off TV at end of day does not turn off amp. Interestingly, this has worked for nearly two years, and only last 2 months have had problem. According to Sharp, the firmware is current and not changed in 1 year. Other symptom of commands not making it to amp are turning off equipment sometimes fails to power off amp, yet it has never failed to start upon power on TV. Sharp tech is as puzzled as I am. Any ideas?
Ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Posted on Jun 28, 2008
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
Older Onkyo Compatability with newer HDTV
Hi rmccormick,
That Tv with the PS3 is a fantastic setup, The tv has one of the best picture quality ratings and the 4ms response time is great for fast action video and video games. The PS3 is a good decision for the Blu-Ray player, for the price you get a great game console along with the player, the drawback is that the PS3 runs alot hotter than a stand alone player, it will need to be well ventilated.
Your reciever will work but you won't be able to watch Blu-Ray in 1080p and that is the pupose of the PS3, you have to use the HDMI output on the PS3 to get 1080p and I doubt your reciever has HDMI, if it does your set if not I would buy a newer model with Dolby 5.1 and HDMI support, or if you want the best go with Dolby TrueHD.
You will need HDMI cables.
Let me know if this helps and please rate this solution. Lone99star
Jan 19, 2009 | Samsung LN52A650A LCD TV
Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Dec 27, 2008 | Samsung DLP HL-P5663W 56" TV
PS3 - Sony Reciever HT-SF2300 - Aquas A83 LCD TV
Make sure you have selected the HDMI output option in the PS3 menu, otherwise you will get no picture or sound, connect you standard cable to your tv first which came with PS3 to do this first.
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
Nov 08, 2008 | Samsung LN-T2653H 26 in. LCD HDTV
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
You may want to try a good, Monster Cable, HDMI cable. Visit this page: http://www.monstercable.com/HDMI/advancedhdmi.asp
If you have a standard HDMI cable, it will not support 1080P.
So this is one of the few times that I will recommend spending the money for a better cable.
The better cable improves picture color quality, from 8 bit to 12 bit and it improves audio quality.
Dec 24, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Samsung LN-T4665F 46 in. LCD Television Logo
320 people viewed this question
Henry  Thomas
Henry Thomas
