Question about Proform Exercise & Fitness
Proform Perspective 1.0 LX panel problems
I have a Proform Perspective 1.0 LX treadmill that runs, but only at 1 mph,and the only button that works is the start button. The incline up button makes a sound when it is pushed but I beleive that is only because the incline is stuck all the way up. How do i fix it?
  • 16 Answers
SOURCE: I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
Posted on Apr 14, 2009
SOURCE: proform 360p stuck on incline
I had the exact same problem.
This usually happens if you switch it off at the mains while the incline is adjusting or is somewhere other than lowest. You should always make sure before finishing off, to lower everything.
Now for the solution: If you open up the case it has 5 or 6 black philips (cross head) screws (use your user manual if you don't have your original go to proform and find the support link and download the .PDF if your model is not available get the one before or after in the same model product line (model number is below the power input)).
Make sure you remove the power before opening the cover, obviously.
Anyway, once opened, you should find a sheet of paper wrapped around in some plastic wallet. On that paper it should explain everything. Try not to mess with too much things in the settings, otherwise you might mess it up badly.
Mine is something like: Hold the speed up (+) button and then while holding the button insert the key - that will get you to the service menu (obviously the power has to be connected).
Once in the menu pressing the incline up does a self-calibration (maximum up and maximum down) after that it should be perfect.
Remove the key any time to come out of that mode and resume normal operation.
I may not find this place for any more replies 'cos i only found this site by accident. While looking for info. on my burnt out motor model: PETL 3013.6 .... But i have come across someone selling a faulty one on ebay for like 5 quids... it's picking it up the trouble!
Posted on May 31, 2009
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jul 16, 2010
Proform perspective 1.0 lx console cycling off and on
There may be a problem with the wire lume that connects the LCB to the console.
Nov 10, 2013 | Proform Exercise & Fitness
Belt is sliding to right and is loose how do I tighten it? Proform Perspective ES
see the diagram attached and use the common sense:
God bless you
8_30_2012_4_32_35_pm.gifthe first if for to tight8_30_2012_4_33_22_pm.gifthe down is for loose.
Aug 30, 2012 | Proform Perspective Es Treadmill PFTL99806
My proform xp 620 treadmill starts up fine and I can walk on it up to 4 mph. However, when I try to go up to 5 mph, the belt stops moving and the display screen goes blank.
1) adjust sensor reed switch or optical disk by 1/8" aprox and replace if neccesary after if the problem persist.
Chech the plug connector console panel vs. and controller board. If everything is wrong the console panel is bad.
Aug 22, 2011 | Proform XP Weight Loss 620 Treadmill
Proform Sport 1000 - The right hand side of my controls which allow me to change the speed of the treadmill do not work. The left side is still operational and allows me to change the incline and select...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Aug 09, 2010 | Proform Sport 1000 Folding Treadmill...
Converting kph to mph
press and hold the stop button while placing the key on, then release and hit speed + or - I don't remember which right now. One turns the store demo on/off and the other is for mph/kph
Jul 14, 2010 | Proform CrossTrainer Treadmill
Proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
May 26, 2010 | Proform Perspective Es Treadmill PFTL99806
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
613 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
