Question about Kenwood Car Audio & Video
Installing Kenwood KDC-MP345U into a travel trailer. Trailer is pre-wired for deck. Have Orange (hot) & White (ground) from trailer converter to deck. Hooked up yellow (battery) wire from harness to orange & hooked up black (ground) from harness to white. Deck wouldn't turn on. Hooked red (ignition) from harness along with yellow to trailer orange & deck worked fine. BUT if I pull trailer into 110 power deck DOESN'T WORK. What am I doing wrong?
  • 122 Answers
The power terminals from the trailer arent direct connected to the battery terminals.when you are plugged to the mains the battery is charging and disconnect [via a relay perhaps]the orange terminal from batt+.try to make anew connection from the trailers battery terminals with a new fuse separated from all trailers circuit'use 2-2.5 mm*cables and a 15amps fuse.connect the yellow and red to+batt and black to- batt.
Posted on Jun 06, 2010
Check power to my trailer brake
12 volt test light or amp gauge. Trailer brakes use 2 wires... 1 ground and 1 hot. The hot has varied amps to apply according to the controller. 12 volt test light works great. use the white (typical) as your ground and the blue (typical) as your hot. Apply brakes. Light should get brighter as the controller is turned up and dimmer as it is turned down. I hope this helps.
Mar 27, 2014 | 2004 Ford F-350 Super Duty
Kenwood kdc-mp345u wiring diagram
Below is the link for the manual, it shows the wiring.
Link:
Mar 08, 2012 | Kenwood Kdc-mp345u Car CD / USB Player
The plug got torn off the the back and i do not no what or were to hook up the break lights nor do i no how to add a plug for a trailer can you please help me out
  • Hi, not sure which one you have so I will list both for you.
  1. Ground - Black
  2. Blk/Orange - Park lamp relay output
  3. Yellow/Pink - Trailer tow right relay output.
  4. White/Pink Trailer tow right turn relay output.
  1. Nothing.
  2. White/Pink - Trailer tow right turn relay output.
  3. Violet/ Black - Back up lamp feed.
  4. White/Red - Fused (B+)
  5. Black/Orange - Park lamp relay output.
  6. Nothing.
  7. Black - Trailer tow brake (B+)
  8. Black - Ground.
  9. Black - Ground.
  10. Yellow/Pink Trailer tow left turn relay output.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 12, 2011 | 1999 Dodge Ram
How do you wire a kdc-mp342u in a ford mustang w/o a harness?
Standard radio color code as follows:RED=switched ignition +12v YELLOw=+12 volt battery(always hot), BLACK= ground, BLUE=remote turn on for amp, OrANGE=light dimmer, White and white/blk= left front , gray and gray/blk= right front, green and green/blk=left rear, violet and violet/blk= right rear
Feb 10, 2011 | Kenwood KDC-MP335 CD Player
All of the sudden my stereo locked up and says protect can't get it to turn off.
try checking your speaker wires and speakers for shorts or grounds. you may also have a bad output ic inside of the deck itself.
Jan 17, 2011 | Kenwood Kdc-mp345u Car CD / USB Player
Cant get out of protection mode when installing kdc-mp345u
make sure none of your speakers or speaker wires are shorting out or are grounded.
Dec 12, 2010 | Kenwood Kdc-mp345u Car CD / USB Player
I am installing a amp. Need to know what color is the remote wire. Is it blue white or some other color?
RED-12VOLT
YELLOW-MEMORY 12VOLT
WHITE-FRONT LEFT+/WHITE WITH STRIPE-
GRAY-FRONT RIGHT+/GRAY WITH STRIPE-
GREEN REAR LEFT+/GREEN WITH STRIPE-
PURPLE REAR RIGHT+/PURPLE WITH STRIPE-
BROWN-MUTE
ORANGE-ILLUMANATION
BLUE-REMOTE(AKA)AMP TURN ON
BLACK-GROUND(NEG.)
Jul 31, 2010 | Kenwood KDC-138 FM / AM Receiver
Installing a kenwood kdc-135 in a 2001 monte carlo ls
Hello, my name is Israel and I will help you. The following should be able to help you out. Please rate and good luck.
constant 12+ orange
switched 12+ yellow
ground black/white
illumination gray/black
dimmer brown white
Left Front + tan
Left Front -
Apr 13, 2010 | Kenwood KDC-135 CD Player
How to install kenwood kdc-x493 with kac-8104d in 1996 honda civic?
very simple on the back of the deck you will have a wire harness
Yellow = constant power supply
Red = Switch power supply
Black = Ground
White = left front speaker +
White /Black stripe = Left Front speaker -
Grey = right front speaker +
Grey /Black Stripe = right front speaker -
Green = left rear speaker +
Green w/ black stripe = left rear speaker -
Purple = right rear speaker +
purple w/ black stripe = right rear speaker -
wires for the honda are,
Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Left Front (+) Blue Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Jul 25, 2009 | Kenwood KDC-X492 Car CD/ MP3 Player
Car Audio & Video Logo
263 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
