Question about Toshiba 50HP66 50 in. Plasma Television
Black screen no video no audio suddenly now
Black screen no video no audio happened suddenly ,now permanently doing nothing
  • 1,869 Answers
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Posted on Jun 26, 2010
    Genius:
  • 1,112 Answers
Check and have the lamp replaced, if it has been at least a couple years since you purchased the set then Its time for a new one...
Posted on Jun 05, 2010
  • Circuit World
    Circuit World Oct 21, 2010
    There are no lamps in a plasma TV to replace, only DLP projection TV's and projectors use halogen bulbs as a light source. seems as though a main ac fuse has opened if so replace it. If it blows again then your bridge rectifier, thermistor, and varistor need to be replaced. those components are responsible for handling in-rush current and current suppression. Let me know if this helps
    http://tvtechwork.webs.com/
My LG LED TV suddenly had black screen as I was watching. There is volume (sounds) coming from it but the screen is all black. What is wrong with it?
Not a good sign... reboot, and try again, if no display but audio, then check HDMI cable or whatever source cable you have by wiggling it to see if video comes back, if no, then most likely repair..
Feb 26, 2015 | LG Televison & Video
Xdvd1262 video no signal
The most common is that the cable that activates the camera is touching ground and this activates the camera and has nothing connected as black screen looks
Feb 24, 2014 | Dual XDVD1262
Black screen - audio works - hp logo on start - then goes black
It is either the power supply or the backlight inverter board finally failed. You will need to do some voltages checking inside, also see if you can see any bad caps in the power supply.
See my troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Jun 15, 2010 | HP LC2640N 26 in. HDTV-Ready LCD...
The screen on my samsung u900v is not working, it is just blue/black, the phone is on as the key pad lights up! Its charging and I can accept incoming calls, i just dont know who is calling as the screen...
The problem with your phone is that the flex on your phone screen is bad and will need to be replace.
All you need to do is just to change the flex of your phone screen and you will see that it will display.
Take care.
May 03, 2010 | Samsung U900 Soul Cellular Phone
Creative Zen M:vision - can't turn on/off, permanent blue light
Well, i didn't charge mine over night, was listening to it in the evening while doing some chores and all of a sudden it stopped playing, Blank screen and permanent Blue light. I tried to turn if off but it didn't respond so i left it. In the morning, it went off itself (guess the battery was low). So i connected to the computer and inserted the ZEN CD. As i was exploring the CD looking for a solution, then all of a sudden the screen came up with a note "Rebuilding..." after 5 secs it came on. With all my files intact! I hope this wud be helpful, You could give it a shot, after all there's nothing to loose!
Jan 15, 2010 | Creative Labs Zen Digital Media Player
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
Permanent split screen down middle by black line
The GPU has overheated that is what causing this problem.
You will need to stop the heat build up and get it repaired - you can even do this with a good guide or send it in.
Nov 01, 2009 | Microsoft Xbox 360 Console
Black screen and numbers 2 and 4 lit
The 2 and 4 LED error code indicatesVideo subsystem configuration or failure”. You either have a bad video circuit or your video drivers have a problem. Try booting into “safe mode” by tapping the F8 key when powering on the computer. If the computer comes up in safe mode then your video drivers may have to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 15, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Black screen, no audio no video
Wow.... Never heard this one before....... I would try using your ps2 with different audio-video cables (maybe just from a friends ps2) If the other cables work than all you have to do is go to your nearest playstation supplier and get new audio-video cables for your ps2. (Walmart Usually sells them)
Hope this helped!!!!!!!!!!!!!!!
Aug 22, 2008 | Sony PlayStation 2 Slimline Console
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Toshiba 50HP66 50 in. Plasma Television Logo
1,372 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
