Question about Saitek Pro Flight Yoke System Flight Simulator
Saitek pro flight yoke problem
Hello there, im using the saitek pro flight yoke, while in flight the view changes uncommanded, it only happens when im using either the yoke or throttles
  • 122 Answers
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Posted on Jul 12, 2010
I have a simple problem with the SAITEK pro flight yoke. The LCD display is backlit, but BLANK. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LCD DISPL
If the LCD is not working then it is likely that required drivers are either not working or missing. Try downloading updated drivers from the Saitek website.
Nov 08, 2012 | Saitek Pro Flight Yoke System Flight...
I have a simple problem with the SAITEK pro flight yoke. The LED display does not turn on. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LED DISPLAY. ...
For how low have you had the Yoke?
This a known fault with the front display on the Yoke failing, it's caused by the LED's being faulty or a inperfect contact there.
If the Yoke functions correctly then it might be one of the above.
If you still have warranty, meaning if you purchased the Yoke less then 2 years ago, try to ask for a replacement for it either from the retailer of from Saitek.
hope it helps...
Apr 03, 2011 | Saitek Pro Flight Yoke System Flight...
Using fs9 with Saitek yoke - aileron control drifts to the right. Had the yoke for several years - it didn't use to do this. Reinstalled fs9 after a year of none use and now have this drift trouble.
The Saitek joystick yoke used to work perfectly. It was only recently that I experienced the aileron drift!
I un-installed and deleted averything related to FS9 and then started to load FS9 and all the add ons etc. The yoke works perfectly again. I have no idea......!
Dec 26, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek yoke's accuracy prroblem.
Try uninstall and reinstall software,
if that doesn't solve then try on different pc
still not working repair/replace unit.
Try Microsoft unit with force feedback or you can buy without FFB for less than £10
Aug 02, 2009 | Saitek Pro Flight Yoke System Flight...
Reprograming the Pro Yoke Hatswitch
Go here --
http://www.fixya.com/support/p921647-saitek_pro_flight_yoke_system_flight_sim/manual-27479
Hope this helps..
Mar 24, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Saitek Pro Flight Yoke System Flight Simulator Logo
448 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
juanmireles1
Michael Vincent Cruz
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
