Question about Kenmore Heating & Cooling
I have a kenmore air conditioner model 580 720 56200, I purchased it around 5 yrs ago, it does cool the way it used to, i've cleaned it, so what else can I do?
5 Suggested Answers
  • 5 Answers
SOURCE: Everstar portable air conditioner
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Posted on Sep 12, 2008
t1m130
  • 86 Answers
SOURCE: RUNS BUT DOES NOT COOL TOO WELL.
if the compressor runs for a short time only it could be overheating due to a lack of refrigerant i would suggest finding a contractor who specializes in hampton bay to take a look at it
Posted on Jul 29, 2009
drifterK
  • 4924 Answers
SOURCE: We've had for three years
The water leaks all over the floor instead of running into the water container. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water container . You've to dismantle the panels to get into this condenser drain pan to have a good clean out... Also check all tubing for wholes and cracks...If you open it ..you probably will see where the water is leaking ...replace and make sure the water evacuation is not corked ..If the water still drains in the container or if it has an external evacuation that seam to be working ..than one of the tubes inside have a leak ..and needs replacing and will be visible once opened..
this water is the effect of the warm humid air ..condensing on the cold parts of the AC unit
Posted on Jul 18, 2011
heatman101
  • 43501 Answers
SOURCE: kenmore window air conditioner model
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 02, 2011
My Kenmore 70088 Air Conditioner have mold
Hello, the coils can be cleaned with coil cleaner that is sold at any heating and cooling store, usually in a aerosol can. The inside of the AC can be cleaned with soap and water. They also sell a cleaner for mold at heating and cooling stores that can be used to get rid of the mold.
May 15, 2012 | Kenmore 70088 Air Conditioner
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
I have a ESP412J-L window unit purchased last summer. After putting the window unit in for this season the ac started off giving cool air up to about a week ago, now it does not give off the cool...
Hello, if you have cleaned the unit, checked the filter , cleaned the coils then either the unit is low on refrigerant due to a leak or the compressor is not engaging due to a bad thermostat on the unit, bad capacitor, or the compressor itself is shot. If its under warranty i would take the unit back to the store and getna replacement.
Jun 12, 2011 | Haier ESA312 Energy Star Window Type Air...
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
Not cooling
it sounds to me like u have a gas leak.you shouldent run the a/c until it gets fixed reason being that the cold suction gas is used to cool the compressor windings.if u continue to to run it you may end up in more expenses:-)
Jul 07, 2010 | Quasar HQ2082UH Air Conditioner
Doesnt cool room as in prev years
yes the side vents need to be outside the window and if they aren't - the unit will not cool correctly.
Hope this helps.
Jun 08, 2010 | Goldstar WG5000 Air Conditioner
Jul 29, 2009 | Hampton Bay HBLG5004 Air Conditioner
Kenmore air conditoner model 580.75151500 keeps blowing the built in breaker on the cord. Air conditioner is only about two years old. Happens no matter where I plug it in
Hi there. Clean the condenser. (the outside cooling coil where hot air comes out.) Use compressed air. If no air, try a vacuum.
Thanks
Paul
Jul 11, 2009 | Kenmore 75085 Air Conditioner
Not blowing cool air
Likely needs freon has leak needs repair local hvac contractor can help. T
Jun 16, 2009 | NewAir ACP-1600H Portable Air Conditioner
Keeps spitting out water whilst in cooling cycle.
Window A/C, correct? If you slide the air conditioner out of it's case. See if the drain on the unit pan is open. Also  make sure that the unit is tilted slightly down toward the outside of the house.  As far as a manufactuer defect. It think he was lieing to you for a service call or he didn't want to do the work I prescribed.
Jan 07, 2009 | LG Heating & Cooling
Heating & Cooling Logo
144 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
