Question about RTO Oar Sockets
I HAVE A 40 HP MERCURY 4 CYL OUTBOARD TRYING TO IDENTIFIE WHAT YEAR IT IS THE S/N 0G297913
How do I remove the mid section on a mercury four outboard engine
Hey Dennis,
What has happened to this engine that requires the Driveshaft housing to be removed? Please give more info/details in a reply to me. Thanks!
I need model/year/HP.. etc..etc..
https://www.marineengine.com/parts/mercury-outboard-parts/100-4-cyl/0g760300-thru-0g965520-usa/driveshaft-housing-usa-0t801000-bel-0p268000-and-up
Jun 04, 2017 | Mercury Boating
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
Gidday,i am trying to find out the year of my 50 h power mercury blue band . The serial number I have is 8016593 and I am looking for both the inner and outer wiring harnesses
50 hp is a 4 cylinder powerhead.. blue band denotes 80s model engines.. my dads was a red band 69 model.. the red band stopped in the late 70s like 79 .. the wire harnesses are almost identical from 40 hp on up to about 80 or higher, just a heavier set of starting cables.. may need to check into used equipment.. might find something easier there.. check mwith a mercury dealer near you also..
Nov 19, 2014 | Light Outboard Motor Boat Bass Fishing...
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
What year is my mercury 40 hp (402)please the number is 9034091
According to marineengine.com, it looks like it could be in the 1983 sequence of serial numbers.
http://www.marineengine.com/mfr/mercury_models.html
Aug 29, 2011 | Seloc Mercury Outboard Engine Repair...
1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Sep 03, 2009 | Boating
RTO Oar Sockets Logo
71 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a RTO Boating Expert? Answer questions, earn points and help others
