Question about Pentair Wf 6 1.5hp Whisperflo Inground Pool Pump
I JUST REPLACED THE MOTOR ON A PENTAIR PINACLE PUNP. I HOOKED UP THE CABLES EXACTLY THE SAME WAY THE PRIOR MOTOR HAD IT. I TURNED ON THE MOTOR AND START WORKING FOR A WHILE, SMOKE STARTING TO COME OUT OF THE MOTOR SO I TURNED IT OFF. I TOOK THE AXLE COVER AND TURNED THE SHAFT EASILY. I STARTED THE ENGINE AGAIN AND RUNS FOR WHILE AND THEM STOPS. THE MOTOR GETS REAL HARD. WHAT CAN BE WRONG?
    Top Expert:
  • Pentair Master
  • 6,949 Answers
Check wiring if 120 volts see side of motor for schematic you might have ruined motor
Posted on May 08, 2016
john224
  • 1378 Answers
SOURCE: need to disassemble pentair dynamo pump to replace
Remove the cover from the back of the motor and lock the shaft from turning. Then spin off the impeller.
Posted on Jun 13, 2009
SOURCE: pentair whisperflo pool pump motor replacement
No there is a cover on the other side of the motor thet comes off and with a 9/16 wrench holding the shaft - spin the impeller off
Posted on Jun 28, 2009
john224
  • 1378 Answers
SOURCE: Pentair WhisperFlo Wiring Help
If you just bought this then there will be a diagram on the motor nameplate and/or under the terminal cover where you connect the wires. Generally speaking, there are two wires inside the motor that change positions depending on 115 or 230 v connection. If one of the wires is on a post common to one of the line leads, that usually means you have the motor set for 115V. Is that the voltage you are supplying to the motor? If there is no diagram you can make out on the motor, post what brand motor and the motor model number for a diagram.
Posted on Dec 24, 2009
  • 64 Answers
SOURCE: pentair pool pump vs 3050
These pumps should not be hooked into an intermatic mechanical timer. It should always have power supplied to it, meaning it should be installed to the line side of the power supply. Scheduling is done either in pump itself or thru an external controller such as a suntouch or easytouch controller, etc. When you have it wired into a timer like intermatic, power is interupted to the pump every day when the timer setting is for off. It is very hard on the drive of this pump, it does not like it, and will shorten the life of the drive. The pump was designed to always have power supplied to it, even when it is not scheduled to run. This may be the problem you are experiencing. HTH
Posted on May 22, 2010
john224
  • 1378 Answers
SOURCE: I have a Pentair 1
Thank you for posting your question here on Fixya.com.
It is the capacitor or the starting switch but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak. Start with the capacitor.
use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although it is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 01, 2011
Pentair Intelliflo vs. Need bearing replacement for front and back bearings
Pentair WhisperFlo Pool Pump Motor Bearings Replaced ...
? 2:03
www.youtube.com/watch?v=qYRNMCh_7kM
Jul 10, 2012 - Uploaded by Pump Repair Supply
More Help & Information: https://pumprepairsupply.com Watch as Joseph shows you how quite your Pentair
Sep 27, 2015 | Pool & Spa
My pentair 2 hp challenger pump turns off after 4 second
since it's a new install is voltage set correct on motor ? this seems possible due to short run time you report
May 04, 2014 | Pentair 2 hp Challenger Pump
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
My new AO Smith motor does not have an L1 IT has L2, L3, and L4 so how do I hook the wires?
There is a schematic on the motor itself to show you exactly how to hook it up. The main thing is knowing whether it's 115 volt or 230 volt connection. Good luck any questions hit me back up.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Apr 26, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
I have a 2HP Pentair Whisperflow pump that has stopped working after only 2 years. When I turn it on, it just makes a humming noise even though the impeller is free. Any ideas?
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Oct 23, 2010 | Pentair 2hp Whisperflo Pool Pump In -...
My pentair plus pump will not turn completely on. It makes a loud noise but never kicks on.
John
Oct 13, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Dec 24, 2009 | Pentair Wf 6 1.5hp Whisperflo Inground...
Punp is runnin hot
motor has too much drag. hopefully something wrapped around shaft, worst case take motor to graingers and replace just motor
May 28, 2009 | Emerson Pool & Spa
Pentair Wf 6 1.5hp Whisperflo Inground Pool Pump Logo
160 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
