Question about Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by
Can't remove the handle hub
Need to replace moen adapter after handle came off. Can't get the handle hub off. Tried to unscrew it--won't budge.
4 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
  • 659 Answers
SOURCE: Reinstalling a handle on an older Moen 84206
Here is the owners manual for your faucet that will guide you through putting the handle back on. Good luck!
http://www.moen.com/shared/pdf/instruction_sheets/INS060B.pdf
Posted on Apr 07, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
How do I replace handle adapter kit for Monticello?
Unthread the handle hub (ccw), once detached, turn the handle upside down. There is a Phillips screw inside that once loosened (ccw) will allow you to replace the adapt.
Feb 18, 2015 | Moen Bathroom Sink Faucet - 4-inch...
Moen 2 handle bathroom faucet is leaking out of base of the left handle
There is a plastic retainer not with two tabs used for removal. You will need a removal tool to get this retainer off. Any plumbing supply that carries Moen should have this tool.
After removing the retainer nut, the cartridge pulls right out. Good luck!
May 23, 2017 | Moen Kingsley Two Handle Bathroom Sink...
Replacing the handle adapter on a 4-inch moen monticillo bathroom faucet. Can't get the handle hub to unscrew with a strap wrench. tried using lime away to cut the 15 years of crud around the handle...
Sometimes there is a small set screw located on the handle.It takes a small allen wrench to loosen it.That should enable you to remove the handle assembly.
Jun 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
Just purchased the home and the handle on the moen 4551 cp is loose. The handle actually falls off the fixture. There is a plastic grommet or washer that is broken. How do I replace this plastic grommet...
You can find the parts diagram here: http://www.moen.com/monticello/chrome-two-handle-low-arc-bathroom-faucet/_/R-CONSUMER%3A4551 . The washer kit is part number 97274. The lever and the hub and elbow that the handle connects to depend on the finish and whether you need the hot or cold side replaced. Levers: 97557 Chrome 97558 Pol. Brass, hub and elbow: Cold 100552 Chrome, 100552P Pol. Brass; Hot 100553 Chrome, 100553P Pol. Brass.
You may be able to find the washer at a local hardware store (like Ace or Tru-Value). Alternatively, call Moen or visit the Moen site. 1-800-BUY-MOEN or http://www.moen.com/replacement-parts/product?product=IMGLIB:CA84437BN to order replacement parts.
You'll have to pay for the washer kit. However, if the hub and elbow or the lever are damaged, call Moen and see if they will replace it under warranty.
I hope this helps.
Mar 08, 2011 | Moen 4551___ Monticello Popular Two Handle...
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
Jan 30, 2011 | Moen & Replacement Cartridge
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I have a 2 handle moen kitchen faucet that is leaking at the base, I do not know how to remove the spout cover..I have tried removing it by prying with a screwdriver but I did not want to force it. does it...
The spout cover is threaded and unscrews then remove spout and replace the o rings with a Moen o ring kit only use Moen brand or Ace Hardware brand
Oct 22, 2009 | Moen Plumbing
Single lever moen shower valve -can't remove handle
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by Logo
556 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
