Question about Ricoh Aficio 1013F Copier
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
  • Edwin Martens
    Edwin Martens Jun 05, 2010
    What is the error message?
  • 903 Answers
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Posted on Jul 19, 2010
How to set factory default at Ricoh Aficio 1013F
Hello sir;You may go to SP mode to print out default setting list;
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Jan 04, 2010 | Ricoh Aficio 1013F Copier
Error msg "sc552,Functional problem" on a Ricoh Afficio 1013F?
You either have a defective thermostat (thermistor) in your fuser, or a defective power supply. The error can only be reset by a tech in service mode after the problem is fixed
Jul 16, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
I have option to buy ricoh 1013F copier i need it to be wireless
If you already have wireless setup easiest way is to purchase a wireless bridge, gives you wireless connection with hard wired port to connect to the copier. Configure the bridge to same wireless settings as your network and plug cat5 cable from machine to bridge setup print driver and you are golden,
Hope this helps,
TankMurdock
Apr 23, 2009 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
How can I print from Tray 2 on Ricoh Aficio 1013F
It needs to be added within the printer driver.
In The Printers/faxes dialog box, "right click" the "Aficio 1013F", click "properties" click the "accessories" (or "change accessories") button, and add tray 2 as an option, Click "apply", and exit the utility, now you can manually select tray 2 when printing.
Feb 20, 2009 | Ricoh Aficio 1013F Copier
How do I stop information page from printing out?
(Reports on/off)-Key operator tools,user parameter,switch03,bits 0 and 5 set to 0.That should do it.
Jun 17, 2008 | Ricoh Aficio 1013F Copier
Won't always print the job
Yes, that is correct, the 1013f is in the same series as the 120.
You can install it as you were trying, or get the latest driver here: http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x12_13/x12_13en.htm#Microsoft%20Windows%20Vista
Apr 17, 2008 | Ricoh Aficio 1013F Copier
Ricoh 1013f Paper creasing
1- you need to determine at what point it's creasing
a) when leaving the tray
b) when getting to drum
c) when exiting copier
2- after that you need to see what the problem is,
a) small paper that was torn off causing problem,
b) is the part worn
c) something out of place
3- remove paper or replace part
Nov 12, 2007 | Office Equipment & Supplies
Text "ghosts" or shadows
Replace Drum or blade(if possible) will fix on most types of copiers/printers, or rarer it is cause of fuser.
Oct 19, 2007 | Ricoh Aficio 1013F Copier
175 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
