Question about Ruud UAKA030 Air Conditioner
Furance I have 2 Ruud Achiever 90 Plus gas furnaces. Units were installed in 2004. One unit flames out after ignition and just prior to the fan kicking in. Confirmed gas valve is functional by switching out valves. Check all wire connections. Could it be the remote sensor or another 24 volt sensor at the IFC that is locking out the gas valve?
    Problem Solver:
  • 18 Answers
There should be a flame rod that senses the flame , if not will shut off gas valve. It is a stainless steel rod that is in the flame path and wires into the panel ground. You might try to clean it with some steel wool or fine paper. Sometimes they will act up with just a little ash or sulphur deposit, even may look clean.
Posted on May 31, 2008
Ruud achiever 90 plus gas furnace flame goes out after few seconds
This could be water in the hoses that connect to the pressure switch , they should just pull off and blow then out also blow out the pressure switch , this sound like a moisture problem with all the bad weather you h, check air filter is not blocked .
Feb 12, 2013 | Heating & Cooling
Ruud 90 Plus Achiever furnace starts, ignites, runs for 30 seconds, goes out, then does it again and again.
It would seem as though you have a bad flame sensor or the ground from the burner to the ignition control is bad...
Could be the ignition control also but not nearly as likely...
Pressure switch can also cause these problems...
Bottom line is that you will need to grab a meter and try to figure out what is causing the flame to cutout...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 14, 2011 | Heating & Cooling
Have a ruud achiever 90 plus furnace. the flame goes out after the igniter quits. any ideas
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 26, 2010 | Ruud UBHC Air Conditioner
I have a ruud 90 plus achiever gas horizontal furnace. the unit will run once i turn the thermostat off then on. it will cycle a few times go off and then will not come on. any suggestions?
Sounds like it could be a dirty or bad flame sensor.
When the burner lights ,there is a flame sensor in the flame and it is suppose to sense the flame and send a signal back to the control board which will keep the gas valve open, if it gets dirty or is bad it doesn't send the signal back to the board and the board will shut the gas valve off and after three tries it will lock out the furnace and you have to reset it to get it to work again.
The flame sensor looks like a wire and it's in the flame usually it will get gas deposits on it, then it won't work.
You can clean this sensor with an extra fine piece of steel wool, but before you attempt to do this DISCONNECT ALL POWER TO THE FURNACE.
Jan 04, 2010 | Ruud UBHC Air Conditioner
I have the same Ruud Achiever unit & it's not working.
It sounds like it will need a hot surface igniter. This is the part that glows when furnace is turned on, and tells gas valve to release gas for it to ignite. At that point funace is lit, it heats up flame sensor witch inturn tells fan to start.
Sep 30, 2009 | Ruud UBHC Air Conditioner
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
The door, you mean the metal cover on the front? if you have the door off and push the safety switch in with your hand everything works fine? I need more info here, but if what I said is right, then the "door" isn't making good contact with the switch.
Mar 05, 2008 | Ruud UBHC Air Conditioner
Ruud UAKA030 Air Conditioner Logo
181 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
