Question about Refrigerators
The water supply line had gotten chewed by the dog. Now the we have the line repaired its up and running. But its got the same noise and not ice is dropping. The noise I am talking about is the same noise that appears when the machine needs defrosting. the water goes in the slots the ice makes but it will not dump
  • nite_angel Apr 10, 2008
    This is not the problem
    Our dog chewed the line. the water ran for 6-8 hours onto the floor. Now it has been turn off and its defrosted. I clean all the water out and the ice cube bin I turn it back on and after about 2 hours it acts as though it has something wedged in it. But this is the first cycle. It does make the same noise as it did when its Stuck with ice cube. Is there anything alse I can do
    Novelist:
  • 184 Answers
IF THE ICE MAKER IS TRYING TO DUMP ICE, IT MAY HAVE A PARTIAL CUBE JAMMING THE EJECTOR BLADES, KEEPING THEM FROM COMPLETING THEIR CYCLE. FEEL THE EJECTOR BLADES, ONE AT A TIME TO SEE IF THERE IS SOMETHING WEDGED BETWEEN THEM AND THE ICE MAKER MOLD. THERE SHOULD ALSO BE ICE CUBES IN ALL THE SLOTS, ALL THE WAY UP TO THE FRONT. IF NOT, THERE IS INSUFFICIENT SUPPLY OF WATER TO THE ICE MAKER.
Posted on Apr 10, 2008
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
What types of toys should be given to dogs that play for a long period of time?
If your dog is very playful and can keep itself busy for an hour or more a day, then you should give it rope and chew toys.
Aug 23, 2012 | Baby Einstein Dogs
I have a Yorkshire Terrier and want to know what the best type of toy is for my dog.
Most small dogs are very active and enjoy getting exercise; so as the owner you should get your dog some toys that will keep them running around and interested. Look for squeaky toys (if the noise wont bother you too much), chew toys, ropes and balls.
Jul 23, 2012 | Dogs
My dog is an aggressive chewer and destroys all the toys we buy
Several claim to be indestructible, but my dog finished them in a day. The bottom line is that dog's chew out of boredom or anxiety. Exercise your dog more rigorously and/or more often, and you should see improvement. If your dog can't hold his/her eyes opened from exhaustion; happy, healthy, and can't chew.
Also, try a horse toy from Tractor Supply or another farm supply chain. They are heavy, durable, and hard to get your mouth around; my GSD loves them. Good Luck!!
May 16, 2012 | Dogs
Dog chewed the gray water mist cord, can i replace the cord?
mcdevito75 here, Best bet, Look for any appliance repair center in your area for replacement electrical line. If your handy yourself or know a handy person, simply match up the electrical cord with another at your local hardware store, Splice the new cord into the old one.
Jul 27, 2010 | Windchaser Outdoor Misting Fan WC161 Stand...
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Sep 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Whirlpool Side By Side Refrigerator
1. How do I get repairs done under warranty?
* If your refrigerator is under warranty, you must use an Authorized Service Company.
An Authorized Service Company can be found by using our Service Locator. Enter your zip code on the Service Locator to get a listing of available service companies in your area.
Back
2. How do I order parts?
* Parts can be ordered through an Authorized Frigidaire Parts Distributor.
An Authorized Parts Distributor can be found by using our Parts Distributor Locator. Enter your zip code on the Parts Distributor Locator to get a listing of distributors in your area.
* You can call our toll-free number to order parts (credit card orders only.)
Please call 800-599-7569 M-F 9:30am - 5:30pm.
Back
3. Noises / Sounds.
* Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises.
The following can be sources of these noises:
1. Dish vibrating on shelf - move dish slightly.
2. Floor is uneven or cannot adequately support refrigerator. Use shims or extra support.
3. Items on top of refrigerator are rocking. Place a pad under the item or remove.
4. Refrigerator is not level. Adjust leveling legs or rollers as needed. Add shims in the back if floor is not level from front to back.
5. Refrigerator is touching wall or cabinets. See your owner's manual for space requirements.
* Snapping or clicking sound.
If your refrigerator is equipped with an ice maker the water valve will snap on when the ice maker is calling for water. This is normal. In some cases you may not have the water connected to your ice maker and the sound will be greater. In these cases, pull the wire signal arm (bail arm) on the ice maker in the up position to turn your ice maker off until the water supply line is installed.
Back
4. Taste and odors.
* Ice or food has a bad taste or odor.
Ice and uncovered foods can pick up odors or taste from strong smelling foods in the refrigerator or freezer. Cover foods tightly and discard old ice.
* Ice tastes like plastic.
Plastic water lines will give off a taste when first used. It takes one or two containers of ice for plastic to stop leeching. Discard initial container of ice after installation.
Back
5. Ice maker - not making any ice.
* Freezer may not be cold enough.
Temperature must be 5 F. or colder to work properly.
* Water supply valve may be blocked or restricted.
Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
* Water supply valve may not be open.
Find and open the supply valve.
* Wire signal arm on ice maker is in the up position.
This position shuts off the ice maker. Pull wire arm (bail arm) down to start ice making.
Back
Sep 05, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
