Question about Computer Associates Kiplinger's CA-Simply Money - Simply the Fastest, Smartest, Easiest Software to Manage Your Personal... for PC (781730712301)
I've been using this software since 1993. It worked in Windows 3.1, 95, 98 and XP. I just bought a Dell 64-bit desktop with Windows 7 and it won't load. Is there a fix available so I can continue using my old friend? Thx, ****
    Scholar:
  • 96 Answers
Its possible that the program is not compatible or wont run in windows 7. for legacy softwares, you can try microsofts XP emulator (XP Mode). you can call dell to check if your computer is cable of using such application. you can download the XP mode from HERE
Posted on Jun 05, 2010
How to change an operating system on the c:/ drive without destroying the information on the drive. Your email address: JCMCJMC68@YAHOO.COM
Your motherboard has to accept 64 bit OS before anything. If it is 32 bit only it will never load a 64 bit operating system. The easiest way to keep all your pictures, music and any other data files is to transfer them to an external USB drive. If you don't have the original software installation disks the software you have on the C drive won't run because the registry will have to be rebuilt. If you do get the 64 bit version of 7 to work, you'll have to upgrade most of your existing software to 64 bit versions. Example: installing a 32 bit version of Word will not run on a 64 bit machine.
Sep 24, 2014 | HP PROMO 8100 ELITE SFF WINDOWS 7 CUSTOM...
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Lenovo k430 won't boot windows 7
might due to harddisk partition and format.
you need to use other utility software to format then only install.
But your recovery parttition will gone.
Never able to restore back to win8
Mar 02, 2013 | Lenovo K430 31092JU Desktop PC Windows 7...
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
When I try to install the program, it says that I may to use a 32-bit system. I have Windows 7, 64-bit. Does this mean that the game won't work on my computer?
Maybe so. As alot of programs and software still recognizes windows xp and not windows 7. I have encountered alot of similar problems with windows 7 and the same program runs well with windows xp.
thanks,
G.
Jun 27, 2011 | The Learning Company Arthur's Thinking...
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
Oct 15, 2010 | Dell Dimension 4700 PC Desktop
I have recently bought a new computer and i installed the software, but the machine will not recognise the computer, can it be installed on computer with the new windows 7 or do i need an update??
Yes, it can be installed on Windows 7. Check the Futura support sight at www.Futura-support.com and look on the right hand side under downloads. There's a download listed for CE150/250/350, etc, that applies to XP 32 & 64 bit, Vista and Windows 7 32 & 64 bit. Follow the directions CAREFULLY! If this doesn't work for you, I've posted a set of instructions under CE100 solutions for running the CE100 software on Windows Vista/7 by installing a Virtual Machine software on Windows 7 that works regardless of the situation.
The update should work for you perfectly, however. Just make sure you uninstall the Futura software and reboot your machine BEFORE you do anything else and follow the instructions from the website carefully! Good luck!
Jul 29, 2010 | Singer CE350
I bought a new laptop from Dell. My old on is a desktop from Dell. I have a Belkin transfer cable. It is asking for a transfer key number. what is that????????
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
Feb 27, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Computer Associates Kiplinger's CA-Simply Money - Simply the Fastest, Smartest, Easiest Software to Manage Your Personal... for PC (781730712301) Logo
394 people viewed this question
Top Computer Associates Computers & Internet Experts
k24674
Jay Plesset
Are you a Computer Associates Computer and Internet Expert? Answer questions, earn points and help others
