Question about Frigidaire GLEQ2152ES Electric Dryer
I got an affinity dryer that threw a code of E4A and e68what is the solution?
Press the start pause button and the cancel button hold them together 30 seconds
Posted on Feb 26, 2012
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: frigidaire dryer error E4A
This is this is the "program Timeout Fault". Meaning the drying time has exceeded program time for that cycle.Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, or bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 08, 2009
  • 172 Answers
SOURCE: error code E4A on my
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
Error code on a Frigidaire affinity dryer EDE, E4A
try going to google and put in the model # and the brand along with the error code.
Feb 24, 2015 | Kenmore Dryers
Tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
I am getting e4a on my gas dryer
Good Afternoon Friend, this is Z. Thank you for your post!
Typically error code E4A indicates that your Frigidaire dryer is experiencing a program timeout fault or max time has exceeded for that cycle. A professional normally checks for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closed with solid door, faulty connection in moisture sensor bar circuit. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your dryer. Hope this helps!
Aug 07, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire dryer code e4a
I understand that you are receiving an E4A error code on your Frigidaire dryer. I do not show an E4A error code for your appliance. I do have an EA4 error code which states improper home wiring. The other possibility is that this could be a false error code. I suggest resetting your dryer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your dryer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Dryers
My affinity electric dryer shuts off after a few minutes, isn't heating, and blinks EA4
That means that the ignitor is most likely failing to start the process to ignite the gas. The ignitor is like a light bulb and can burn out.
Here is a link to the information about that: http://www.managemylife.com/mmh/questions/289969-frigidaire-model-faqg7077ka-error-code-e4a-heat
Aug 14, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My dryer will spin and then stop spining reading err68 or err4a what can this mean.
E4A = The drying time has exceeded program time for cycle. Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for any thing that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closetwith solid door, or bad connection in moisture sensor bar cir cuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
68 = One of the keys (buttons) is stuck closed (active). Enter function testmode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists, replace electronic control
Dec 31, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
Error code E4A on my frigidaire affinity dryer
Mike Anderson
(865)945-3808
Dec 02, 2008 | Frigidaire Dryers
message "ad" showing on my affinity frigidaire, anything wrong with this?
Apr 01, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
330 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
