Question about Dual Electronics SDI IH51 SDI Ihome 2.1 Micro Bookshelf System With Dual Alarm Clock Radio Battery, Speaker System, Clock Radio for Ipod, brand by SDI...
Subwoofer doesnt work - Dual Electronics SDI IH51 SDI Ihome 2.1 Micro Bookshelf System With Dual Alarm Clock Radio Battery, Speaker System, Clock Radio for Ipod, brand by SDI...
  • Mike Ayer Jun 22, 2010
    I set it up correctly over a year ago when I first bought the system. It used to work then just stopped.
    President:
  • 1,561 Answers
Have you check the user manual to see how the subwoofer is connected because this might simply be be connection problem, check the user manual for the right connection and follow the procedure to connect your subwoofer, with this, i believe it should work.
Take care.
Posted on Jun 13, 2010
External subwoofer doesnt play any sound
Are you plugging the sub into a 3.5mm jack or USB?
Have you tried to plug the sub into the speaker jack?
The sub works on another computer?
Bad sub or bad jack?
I hope this helps!
Jan 22, 2013 | Dell Inspiron 1545 Notebook
Cant get my sub to work on my denon avr2808 and dont think it ever has it doesnt even work on the test signal
Hello
There are four possibilities that the subwoofer doesn't gives any aoutput. They are:
• Subwoofer's power not turned
on.
•The "Subwoofer" setting at
"Speaker configuration" is set to
"No".
•The subwoofer is not properly
connected.
•The subwoofer's volume is
turned off.
Go to its manual setupscreen, come to speaker setup, speaker confuguration, come towards Sub Woofer, select "Yes" and press OK.
Mar 21, 2011 | Denon AVR 2808Ci Receiver
My subwoofer is connected correctly (test mode it works fine). The Denon 589 receiver, however, when everything is set up and ready to go, doesnt seem to send any output to it, so there is no base sound. ...
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
Jan 18, 2011 | Denon AVR-589 Receiver
Hooked up the subwoofer and it doesnt work at all is the a subwoofer on and off button for this receiver
No, you have to follow the procedures in the manual to inform the unit that there is a subwoofer, then select some parameters on how it is used depending on the functional sizes of your other speakers.
http://www.retrevo.com/s/Denon-AVR-1603-Receivers-review-manual/id/363bh846/t/1-2/
Page 10
Aug 16, 2010 | Denon AVR-1603 Receiver
Does not want to work
to make sure it's the subwoofer at fault and not the amp, speaker wire, rca's, radio, power, or ground wiring, you should, if possible, hook up a known good subwoofer to see if it works properly. if it doesnt, check fuses, grounds, the remote amp turn on wiring, etc. it could even be something as simple as a setting on the stereo itself. if the substitute subwoofer does work properly, double check to be sure the original sub is wired correctly. if it is, i'm afraid you've got a faulty/bad subwoofer. I hope this helps and good luck!
Feb 17, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofer doesnt hit hard at all with this amp.
set gain to match head unit.its not a volume control.turn bass up.on unit and amp.and not knocking what you have but sony well theres much better.
Nov 14, 2009 | Sony XM-2200GTX Car Audio Amplifier
Subwoofer dont work at all
That sounds like defective internal wiring or a loose connection on the amplifier PCB. If you just purchased this audio system. It should still be under warranty for a defect.
Feb 06, 2009 | Panasonic SC-PT1050 System
I have Harman Kardon speakers and subwoofers connected to a Denon AVr 1508 receiver. All my five speakers are working but my subwoofer doesnt work. I m pretty sure I have connected the subwoofer properly...
There is a setting under your speaker setup to turn the subwoofer on. If speakers are set to small it auto matically sets the subwoofer to ON. If the speakers are set to large it turns the subwoofer off but you can manually adjust.
May 02, 2008 | Denon AVR-1506 Receiver
My subwoofer doesnt sound
check your manual
If you dont have one , you can websearch one very easily.
Dec 09, 2007 | JVC TH-M505 System
Rattling subwoofer
If you can smell burning I would say your voice coils are shot... My friend has a older Kicker subwoofer and it was doing the same thing you described... We took it in and the audio repair shop said it was toast.
Mar 28, 2007 | Kicker Solo-Baric S12L5 Car Subwoofer
Dual Electronics SDI IH51 SDI Ihome 2.1 Micro Bookshelf System With Dual Alarm Clock Radio Battery, Speaker System, Clock Radio for Ipod, brand by SDI...  Logo
67 people viewed this question
Top Dual Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dual Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
