Question about Bissell Upright Vacuum - The Pet Hair Eraser 1 ea Vacuum
New Belt, but can't reinstall brush correctly
I replaced the belt for the brush, but I cannot get the brush back in a position where it can even spin. The white end of the brush has a circle slot that slides right in, but the black end is like a rectangle and I don't understand how this can possibly allow the brush to spin. Any tips on putting the brush back in so it can function properly?
  • 736 Answers
The rectangular and round ends are not intended to turn ..they stay fixed.. the bearing is inside the brush next to the round and rectangular ends .. if the ends dont move freely then there may be hair or string wound around the bearings .. clean that out so that things turn freely (the end may even come off) ... once you have things free and clean .. then putting the brush back in place does take some strength .. the belt gets very tight and its difficult but possible to get the rectangle inserted in its slot ..
Posted on Jun 07, 2010
How do I replace the belt for this model
Make sure vacuum is not plugged in to power outlet. Lay it upside down and remove 4 screws from bottom plate covering brush roll. Remove bottom plate and pull the brush roll out. Clean hair and debris from brush roll and make sure it spins freely. Remove end caps from brush roll if possible and clean debris out. Install new belt around motor shaft then insert brush roll into belt and pull on brush roll to give you enough leverage to stretch belt far enough to put. Brush roll back into position. Reinstall bottom plate and screws. Make sure brush roll will turn before turning vacuum back on. Belt will lose elasticity and should be replaced twice a year.
Jan 17, 2015 | Hoover U5434-900 WindTunnel Plus Bagged...
Tip
Common generic problem with Dyson upright vacuum brush bar
I see lots of problems with Dyson vacuum cleaner brush bars not revolving, this is normally because the belt has broken, this is an easy and relatively cheap fix. Remove the sole plate normally held by a couple of quarter turn plastic connectors, once the sole plate has been removed the brush bar can be lifted out of it's slotted position, remove the remnants of the old belt. With the new belt manouvre it over the motor spindle first then position brush bar through belt and slot the brush back into its slots and reattach sole plate. This procedure should take no longer than ten minutes even for a total novice.
on Apr 16, 2010 | Vacuums
Belt issue
Check the switch to the brush bar it might not be in the right position it needs to be in to run or not run should be in a little slot that turns it on and off
Apr 18, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
My Hoover makes louder noise when the brushroll is on. I just cleaned but no result.
What kind of Hoover is this? There are a few things that will cause excessive noise and vibration such as a worn belt, the wrong belt, damaged end caps, damaged brush roll housing and worn bearings. Inspect the brush roll area. Remove the belt, if you have a spare, check the size. If it's more than 6 months old, replace the belt. Spin the brush roll in the housing, does it spin free or hesitate or not turn at all? If it spins with effort there could be debris under the end caps; if one end cap will not turn there is enough debris to cause the end cap to internally melt to the roller. If you cannot turn the brush roll by hand, replacement is your best solution. You should also inspect the housing where the roller spins, specifically where the end caps sit; look for damage to the slots in the plastic, it the roller will not sit snug this could cause enough vibration to make the sound you're hearing.
Sep 20, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
8955 Upright Vacuum: How to change belt?...
Be sure to unplug your vacuum from the electrical outlet before proceeding!
-Turn your vacuum upside down so that the handle is resting on the floor and nozzle portion is resting on a work bench.
-Remove the 2 phillips screws from the metal bottom plate and set the bottom plate aside.
-Look at the right side of the brush roll. You will see a bent metal rod that attaches to the brush roll end cap. This is the clutch rod that allows your brush roll to spin or not depending on the position of the carpet/floor switch on the top of the nozzle. Pull this rod out of the brush roll clutch only. Leave the switch end of the rod where it is and just let the rod rest there.
-Pull the brush roll and old belt out and dispose of the old belt.
To install a new belt; put the new belt on the motor shaft first, next put the other end of the belt over the end of the brush roll and stretch belt and brush roll back in to place. Notice that on the brush roll end cap opposite of where the clutch rod goes, there is a metal piece with a slot cut into it. Be sure that this slot mates with the plastic stop in the nozzle so that the end cap cannot move.
Snap the clutch rod back in place and rotate the brush roll by hand to make sure the belt is not pinched.
Replace the bottom plate.
May 18, 2010 | Riccar 8955 Upright Vacuum
The brush motor starts and stops during use
Is it the actual motor stopping or the belt that spins the brush that's slipping? if its belt slip, this happens, pretty common on all belt vacs, dirt and dust gets under the belt and causes it to just slip with no actual grip on the brush end. This slipping can also cause to much friction ware and actually changes the inner diameter of the belt so even cleaned it would still (maybe) slip so need a replaced belt.
But I'd take the belt off first and clean it as well as the heads it spins over then try it again. Make sure you unplug from the wall, a vac brush can and will take your fingers clean off.
Jan 01, 2010 | Hoover U8120-900 WindTunnel V2 Bagged...
Bissell 7920 proheat
sounds like you didn't get the ends of the brush roll in the slot, where the red piece goes, there is a slot for the end of the end cap to fit into,
Jun 09, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Miele White Star SEB 204, powerhead stopped spinning. brushes are clear of debris, belt (#3854940) is not broken. Could belt be stretched so that brush head does not spin?
Yes, most likely the belt has stretch. Flat belts do this after a short time and need to be replaced when problems start with the brush roll not wanting to turn. Also check the brush roll, make sure that the ends turn freely, if not, then replace it also.
May 20, 2008 | Miele Vacuums
My brushes are not turning. We checked the gear and it is turning, but brushes aren't
Take the brushroll out and see if it turns freely just by holding the end. Also make sure that the belt isn't stretched out. Also, before putting the head on the vac, you have to pick the belt up on the "finger" that's in the head. You can verify this by looking into the circle that's cut out of the metal. When the head is affixed to the vac, then turn the belt lifter back around to the proper position and all should be well. If you still need help, you may call us at 1-866-509-1952. Thanks
Apr 05, 2007 | Kirby G5 Bagged Upright Vacuum
Bissell Upright Vacuum - The Pet Hair Eraser 1 ea Vacuum Logo
651 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
