Question about Haier HBF05EABB Beer Despenser
HAIER hbf05ebss beer dispenser compressor not starting
My HAIER hbf05ebss beer dispenser just broke. The compressor is hot and does not start. This happened to my kitchen fridge a year ago and the technician said the compressor and motor must have broke but he did not use any tools to prove this. So I just replaced the control board myself and it worked fine. So I am wondering maybe the same type of issue.
So I would like to know where to get the parts diagram and parts list for hbf05ebss. I would like to know if there is a control panel which controls the relay, motor, and compressor and which other parts may be defective. What is part number for relay, control board, and other components which start the compressor? I really doubt the compressor is bad.
  • karlgundal Jun 05, 2010
    I took out the start relay and measured resistance and it was open circuit. It is supposed to be 0 ohms at room temp. Just ordered part....hopefully fixes issue.....
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my haier beer dispenser model HBF05EBSS will not
Try to change the capacitor and start relay first...then maybe if that don't work the compressor...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
  • 489 Answers
Just In case You want to see how to replace compressor on refrigerator, I made video. Check it out. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Posted on Feb 04, 2015
My haier watercooler does not dispense cold water it dispenses warm water please help
The cooling circuit is not working - check for a bad compressor or bad start relay/capacitor.
Aug 31, 2017 | Haier Refrigerators
Not starting
ck that you are getting power to it some of them have fuses on them , the switch may be bad
Mar 28, 2014 | Haier Kegerator HBF05EBSS Draft Beer Tap...
I have a kegerator. It's not functioning. When plugged in no clicking no sound nothing. Wondering if it's the overload switch or relay.
http://www.haieramerica.com/en/asset/product/1ffd77cfa0
This site has your product manual for your dispenser but it is very vague on trouble shooting the cooling system.
In general, the compressor is controlled by a thermostat that is usually located in the conditioned space. It cycles the compressor on and off based on the sensed temperature and the setting that it is adjusted to.
So, let's talk in general refrigeration terms. Where the compressor is located, is there a fan? If so, is it running? That fan is usually the condenser fan and is wired to come on anytime the compressor is supposed to be running. If the fan is running and the compressor is not, then there is an issue with the compressor. If the fan is not running and the compressor is not running, then there is an issue with either power or the thermostat. If the compressor is running and the fan is not, then there is an issue with the fan.
This is a good starting point. Let me know if I can be of further help.
Mar 24, 2011 | Haier HBF05EBSS Commercial Beverage...
I have a 2 year old Haier kegerator and it seems to have stopped working. I hear a clicking sound which I believe is the compressor going on and off. I have done some research and found that this is a...
Do you have any technical background? There is a simple and sure fix to this but you will need to be able to read a wiring diagram and have basic electrical tools like a wire stripper and electrical tape.
Dec 02, 2010 | Haier HBF05EBSS Commercial Beverage...
My haier beer dispenser model HBF05EBSS will not turn on. Compressor is hot and keeps clicking on and off. How can I fix
heatman101
Aug 31, 2010 | Haier (HBF05EAVS) Beverage Dispenser
Compressor kicks on, but unit does not cool
refrigerators dont come with shrader valves. U must buy a clamp on or weld one on the low side. The clampons are not expensive and are called Bullet piercing valve BPV 31 and fit 3 sizes. Unfortunately u also have a leak somewhere. Most refrigerators use either R12 or 134a
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Feb 28, 2018 | Haier HBF05EBSS Commercial Beverage...
When plugged in, the compressor never kicks on. It just clicks.
If the compressor is getting hot then the compressor is gone. But the price on a relay is fairly cheap so you can at least try it and if it doesnt work then return it and dump the unit. But like I said before when a compressor gets hot it means that the piston is bad and the rings are burnt and the oil is bad in the compressor.
Feb 13, 2009 | Haier HBF05EBSS Commercial Beverage...
Can I replace a damaged evaporator coil?
Well, the old screwdriver through the evap trick huh?. you planned on repling evap coil and recharging with 134 a? correct??if you have that knowledge and ability then installing a charging port would be least of issue. sorry for sarcasm but not a do-it-yourself fix honestly bring it down to a local repair guy
Feb 29, 2008 | Haier HBF05EBSS Commercial Beverage...
Haier beer dispenser model HBF05E
Either its not getting cold enough to shut off or your thermostate isnt working.. thats the only thing that cycles it.
Aug 27, 2007 | Haier (HBF05EAVS) Beverage Dispenser
Haier HBF05EABB Beer Despenser Logo
174 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
