Question about Brother MFC-9420CN All-In-One Laser Printer
Brother MFC9420CN Toner Error-Incompatible Toner Detected
I refilled the black cartridge on my Borther MFC9420CN printer. It worked great for awhile. But all of a sudden one day it stopped printing and gave an error code (Toner Error-Incompatible toner detected).
When I removed the cartridges, black toner was everywhere. The cap was very loose when I replaced it, and it had fallen into the cartridge.I fished it out and reseated it.
I have rebooted, taken the cartridges out. I continue to get the same error.
I called Brother and they told me to replace the cartidge. Those things cost $169. That is why I refilled it in the first place.
My best guess is that there is a preset on the cartridge, or on the machine, that will allow only a certain number of prints per cartridge so that the Brother Cartridge Mafia can extort more money out of people by making them throw away a perfectly good cartridge.
Can anyone tell me how to get around buying a new cartridge?
  • aated Nov 04, 2008
    hello i have the same problem
    1 + 7 did not help me
    i still have the same massage
  • gigahtz Nov 07, 2008
    I have the same toner error and i have replaced all the cartridges. I also downloaded the service manual and it say to use only Brother cartridges. i also did the reset that was described, and i still have the error.
Since this machine takes TN04 cartridges, and there are no chips or anything, do a reset.From memory press 1 and 7 together, then 1.
Posted on Apr 14, 2008
Ok i hit 1& 7 at the same time and pressed 1 to reset opc belt, then i hit 2 and 8 at the same time and pressed 1 to reset fuser. i took each of the catridges out vacum cleaner them and then on the right side rotated the cylinder a few times to ensure they were locked as i notticed some toner being released. (did this for all toner cartridges). I then put them back in and the system reset and strated printing. I believe the later cleaning and rotatiing the cylinder of the catrridge did the trick. Hope this is helpful.
Posted on Feb 08, 2009
Toner error
There are chips on the toner cartridge, that how the printer known it got a new cartridge so refilling does not work.
Jan 05, 2014 | Konica Minolta PagePro Office Equipment &...
MFC 9450 - CDN shows toner end of life message. The cartridges had been refilled from bottles. This was solved by resetting the flag gear so the printer thought it had a new cartridge. See this link. As...
You can reset the toner bias by opening the front cover of the printer so that you can see the toner cartridges and then press "clear/back".
This will access the toner reset menu and you can select which cartridge you are reseting.
Mar 25, 2010 | Brother MFC-8460N Laser Printer
My Brother HL-2170W only gets about 300 pages per toner cartridge unless I put a piece of masking tape over the whole in the cartridge through which the printer ascertains how much ink is left. When I...
It is perfectly safe to cover the sensors on either side of the cartridge. What works best is to cover it with a piece of black electrical tape. The cartridge is set up so that when you put it in the printer, the printer shines a laser from one end of the cartridge to the other. This laser reads the toner level. If you cover both sides up with tape, it tricks the printer into thinking the cartridge is full of toner.
Hope this helps! :)
Mar 23, 2010 | Brother HL-2170W Laser Printer
I have a brother 2140 printer, it ran out of toner and i refilled toner starter cartridge , and error message comes back to clean the corona , i replaced ther cartridge with a new tn-360 cartridge, but...
When it says to clean the corona, on the drum there is a purple tab that moves from one side to the other. run it back and forth a couple times that should solve the problem.
I dont recommend refilling the cartridges, we have had several issues in repairing those printers with refill. if you must use refills, i would recommend getting 2nd or 3rd party manufacturers.
if you need help, you can contact us.
thanks adi
Dec 31, 2009 | Brother HL-2040 Laser Printer
Brother Toner Refills
Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
They also have great customer service. I hope this helps!
Nov 08, 2009 | Brother DCP-7040 Laser Printer
Printer smears on cold print
The toner cartridge sounds like the problem to me. Did you refill it? Or have it done? It sounds like an incompatible brand......toner is very model specific, and not just 'any' will do, and it often doen't mix well with the remaining toner i the cartridge if it is not completely disassembled and cleaned out. Just curious
Mar 16, 2009 | Brother HL 5250DN Laser Printer
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Jan 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Borther mfc210c black ink not printing even after cleaning
if your brother machine is within warranty, give the tech support a call. if not,replace the black cartridge with a new one. it may be a defective cartridge that you have or if you are using refilled cartridges, it will also give the same problem
Nov 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Dont recomend refills causes too many problems, like you are experencing, put in a real brother toner should fix problem.
great link to explain of lights on panel
Dec 18, 2007 | Brother HL-2040 Laser Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
968 people viewed this question
James Cagle
James Cagle
Jim Keysor
