Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer thew a code of E4A any idea what caused it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error E4a is a communication error which means the control board has gone bad and should be replaced to resolve the issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 05, 2010
Error code on a Frigidaire affinity dryer EDE, E4A
try going to google and put in the model # and the brand along with the error code.
Feb 24, 2015 | Kenmore Dryers
I am getting e4a on my gas dryer
Good Afternoon Friend, this is Z. Thank you for your post!
Typically error code E4A indicates that your Frigidaire dryer is experiencing a program timeout fault or max time has exceeded for that cycle. A professional normally checks for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closed with solid door, faulty connection in moisture sensor bar circuit. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your dryer. Hope this helps!
Aug 07, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
How do i fix error code E4A frigidaire dryer
Good Afternoon Friend, that's a great question!
Typically error code E4A indicates program timeout fault or the max time exceeded for that cycle. A professional normally checks for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closed with solid door, faulty connection in moisture sensor bar circuit. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your dryer.
Jul 19, 2014 | Frigidaire Dryers
Frigidaire dryer code e4a
I understand that you are receiving an E4A error code on your Frigidaire dryer. I do not show an E4A error code for your appliance. I do have an EA4 error code which states improper home wiring. The other possibility is that this could be a false error code. I suggest resetting your dryer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your dryer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Dryers
My affinity electric dryer shuts off after a few minutes, isn't heating, and blinks EA4
That means that the ignitor is most likely failing to start the process to ignite the gas. The ignitor is like a light bulb and can burn out.
Here is a link to the information about that: http://www.managemylife.com/mmh/questions/289969-frigidaire-model-faqg7077ka-error-code-e4a-heat
Aug 14, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Displays code E4A , clothes will not dry
Hi Alicia Rosa - Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Nov 25, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer displaying code E4A, clothes are not drying
Hello - Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Nov 25, 2012 | Frigidaire Dryers
Error code E4H
Hi - Are you certain the error code is E4H? This manufacturer does not have such an existing error code however Frigidaire does have an error code E4A. Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Oct 17, 2012 | Frigidaire Electric Dryer
Frigidaire electric dryer aeq7000es1 low heat only code e4a store
this is a door switch issue make sure the door switch is not broken
Sep 14, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Error code E4A on my frigidaire affinity dryer
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Dec 02, 2008 | Frigidaire Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
116 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
