Replaced a one speed 230volt 1 phase electric motor with a two speed 230 volt 1 phase electric motor, now have extra wires which color wires do you use or cap??
  • 674 Answers
Look at the old motor and see what the rated rpm was. Next look at the new motor and see if it gives a speed for each wire. If it doesn't give the speed for each wire then look at the rated motor speed. That will be the Hi speed. Hook up the wire that matches the speed of the old motor and cap the other.
Posted on Jun 06, 2010
I have a 1/2 horsepower electric motor 230 volt 3 speed w/ capacitor HVAC fan assembly. how do I wire it to power by color coded wires?
Keeping in mind that some motors may be different
The most common wire colors on a 3 speed motor are as follows:
Red- Low speed
Blue- Medium speed
Black- High speed
Brown capacitor wires ( usually two of them connect to the two capacitor terminals doesn't matter which wire to which terminal)
White - Neutral wire on 115 volt systems or the other 115 volt side of a 230 volt system ( note on a 230 volt motor this wire may not be white). Remember this is the most common wiring but different motors may have different wiring.
Hope this helps.
Bob
Nov 30, 2014 | Heating & Cooling
How To Interpret Or Read Nameplate On 3 Phase Motor?
The higher the voltage the lower the amperage, so advantage is its more cost effective to run it at highe voltages since power consumption is I squared x Resistance. The resistance will be the same but the lower the current the less it cost to run it.
Jul 27, 2014 | Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8"...
T-30 wiring changing from 460 volts to 230 volt 3 phase
There are several items that will need to be changed or replaced. First rewire motor. Remove weather head cover. On the motor will be a tag that shows how to wire for 460 volts and 230 volts.Check the tag and present wiring to make sure they match. Then look at the 230 wiring and change wiring per motor tag. Again check the motor tag to see max amps at 460 volts and 230 volts. 230 volts will be higher than 460 volts. Check the starter (if so equiped) to see how many amps its rated for. You will probably have to replace the starter. Make sure it has a 230 volt coil. Next size the overload heaters for your amperage. This conversion is not a simple task unless you're familiar with electrical . Good luck!!!
Next the starter coil will need to be replaced with a 230 volt coil
Nov 27, 2011 | Ingersoll Air Tools & Compressors
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
How to conect 3 phase motor 9 yellow wires from t1 to t9
There is no neutral on 3 phase. They are all power wires. If you try hooking up a 3 phase motor to single phase power it won't work.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
How to conect 3 phase motor 9 yellow wires from p1
Connect t4,t5,t6 together. Connect t1,t7 together for line 1. Connect t2,t8 together for line 2. Connect t3,t9 for line 3.
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
