Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Tightening the chain
Bought a 18 inch Mac 3818 used from a friend chain is loose not sure how to replace or tighten. Also need to know fuel mixture.
    Brigadier General:
  • 4,088 Answers
Fuel ratio is 40:1 using modern chain saw oil--not any petroleum base oil like boat motor oil. Be sure to premix fuel and oil in it's own container and to shake vigorously just before filling the saw each time. To remove the chain, loosen the chain adjustment screw several turns CCW, release the chain brake, and remove the side nuts that hold the rear chain cover. The cover will just pull off, then the bar can be pulled rearward somewhat and the chain worked off of the bar. Remove the bar by pulling it outward. Clean the entire area where the bar and chain fit to the engine, then clean the bar oil ports that run from the larger holes out to the chain groove on each side of the bar. Start the engine with bar/chain removed--oil should ooze out of the side port where the bar fits to. If ok, and the chain appears to be relatively unworn, refit everything in the reverse order of removal, making sure that the chain teeth cut toward you on the bottom run, and the chain adjustment tang drops into one of the large oil holes when replacing the cover. Tighten the mounting nuts only finger tight, and adjust the chain screw CW until the chain ceases to droop from the lower side of the bar, yet not so tight that it can't be turned by hand. Tighten the mounting nuts firmly and recheck the chain tension. If ok, and the engine runs well, start the machine and hold the bar tip near some cardboard while running at speed for several moments--it should throw off a thin line of oil onto the cardboard. Use common chain/bar oil available from home centers, hardware stores and saw dealers. Make sure the chain is properly file sharpened. Hope this helps!
Posted on Jun 05, 2010
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
Tighten chain
Follow the procedure in your owners/service manual. Otherwise, I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Oct 12, 2013 | Mcculloch 16" Electric Chain Saw Mcc3516f
Chain coming loose
Yes. Loosen the two nuts on the back wheel. When they are loose just pull the wheel back until the chain is tight enough and tighten nuts while holding the tire in the proper position at the proper tightness of the chain. Make sure that the tire is running true when tightened.
Jun 24, 2012 | Dynacraft Cycling
How to tighten a chain on a Polaris 325 Trail Boss
fist you have to jack the rear end up then loosen the two pinch bolts on the bearing housing. the housing will be right in the centre of the axel. you hve to check your sprockets to make sure theyre still in good shape. like no teeth missing or rounded teeth. if there is replace the chain and sprockets.if there good just have to turn the housing to tighten up the chain. leave a little bit of slack, about 1/2 inch. check slack by sitting on it and check the play in it.
Jun 08, 2012 | Garden
I have an 18 inch bar and the chain has to be tightened every few minutes. I tighten the nuts against the bar as tight as I can but the bar must still be moving to loosing the chain. Do I need to add lock...
There is an adjusting pawl with a screw that does the tightening. The nuts only clamp the bar once the chain is tightened. The adjusting screw is in the plane of the bar. The pawl may have disengaged the bar or may have broken.
Jan 01, 2010 | Poulan PP4218AV 18" Chain Saw
I want to know if I replaced the chain on the correct way
8a149b6.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Oct 20, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi battery chainsaw 10" - How do I tighten the chain?
loosen the two nuts that hold the chain cover on. Once they are just loose, then use a flat blade screw driver to turn the slot that you see right next to the base of the chain. Once the chain is tight, retighten the two nuts.
May 23, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Fix the tension tightener for ryobi chainsaw
the nut like end of the tention bolt should fit into a hole in the bar. Then as you unscrew the bolt later one it ill push the bar farther away from the bolt heal thus tightening the chain
May 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chainsaw chain came off/is loose
You need to tighten the chain, and or remove and reinstall the chain depending on whether or not it has come off the drive wheel. The chain drive is on the right hand side of the saw, and there are either two nuts (about 1/2 inch or 13mm) holding the chain on, or there is a little half round handle you can use to tighten the chain after it is on the drive wheel properly. The saws with the two nuts on them have a small flat blade screw on the backside on the bar that you tighten the chain with. And to make things more confusing, some of the newer bars have a round hole in them, that after you loosen the two bolts, you stick a screwdriver in the hole and turn it clockwise to tighten the bar, then you re tighten the 2 nuts.
Since from your description that it wont engage to cut, you will have to remove and reinstall the chain since it is loose from the drive wheel. Clean out all the wood chips, etc in the drive wheel area before you reinstall the chain, make sure it is not on backwards and sharpen and oil it before you use it. Rick
Apr 11, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Cannot tighten the chain bar
Make sure the bar is positioned on the bar adjusting pin before you tighten cover. Adjust tension with bar adjusting screw, then tighten bar bolts.
Mar 25, 2009 | Poulan PP4218AV 18" Chain Saw
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
284 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
