Question about Electrolux Epic 6500 Vacuum
How take hose apart on electrolux epic 6500
Something is stuck in the house. How do I take hose apart on electrolux epic 650
LizDahl
  • 75 Answers
SOURCE: Electrolux Epic 6500 Powerhead Motor
Call an Aerus Electrolux dealer in your area.
Posted on Jan 29, 2008
LizDahl
  • 75 Answers
SOURCE: Electrolux Epic 6500 Power head
Call your local Aerus repair shop.
Posted on Feb 27, 2008
  • 44 Answers
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Posted on Jan 01, 2009
SOURCE: cord won't rewind. How do I take apart to repair?
see jan 1, 2009
Posted on Apr 19, 2009
SOURCE: i have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Posted on Jan 30, 2010
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Accessory compatibility between Electrolux Models 1521 and Epic 6500 SR
No, they have different connectors. 1521 uses a pigtail hose that has little metal clips. 6500 has a plastic end with an arrow that helps guide you for proper placement. Unfortunately you will need 2 separate hoses for the respective models.
May 12, 2015 | Electrolux Vacuums
Unclog vacum hose
Disconnect the hose from the canister and connect it to the blower end of the canister and this should blow out the debris or rag stuck in the hose.
Jul 21, 2013 | Electrolux Epic 6500 Vacuum
Hi I have something stuck in the handle of my Epic 6500 series vacuum cleaner. How do I detach it from the hose? Thanks Marina
take your tool caddy off and after filter insert the hose into the exhaust port turn the vac on the object should come out you may have to place your hand over the handel to build up back pressure a few times if it doesn't come out at first
Aug 02, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
Parts for Electrolux Epic 6500
You need to look under AERUS Electrolux to find a Dealer with parts.
Electrolux USA sold the brand name back to AB Electrolux of Sweden a few years ago and there is no relation between the two.
You may also find a common component of a different color at a Tri Star dealer as they shared some power head and hose technology in the era of the EPIC although they don`t tell people that
Sep 14, 2009 | Electrolux Epic 6500 Vacuum
We replaced the motor on our electrolux epic 6500 but the temperture light comes on and machine willnot run.
Check for blockage in the hose or the sweeper. Check the filter located under the grill on the top back of the machine.
Jun 15, 2009 | Electrolux Epic 6500 Vacuum
Electrolux EPIC 6500 won't stay on
find and clean all filters,if an air compressor is available take it apart what you can and see if you can get to the motor and blow it out and check for restrictions in hoses,motor has overload protection and dirt will make it overheat and shut off when it cools down then it works again and or check electrical cords and sawitches
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
158 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
