Question about Kenwood KW85 Air Conditioner
Why is my unit not pushing air thru the vents? AIr is not cold?
My unit is not pushing air thru the vents and the air is not cold
Heater and ac controlls not working 1994 corvette
Are all the vents working? Does your Cruise Control work (properly) it may work and shut off. If your vents are working is only hot air or cold air coming thru, or just your defroster vent?
You have a 3 way check valve under fuel rail guard on passengers side, its a pastic barrel shape thing it rots and creates holes in it causing your ac vents and cruise control to malfunction.
next your heater control unit if you have the one with a slider to regulate the hot or cold temperature breaks easily inside unit, its only plastic. Its an arm inside unit to control the temp in car it slides a door open or closed for heat. If you look where he slider enters thru that hole space you will see a post it sits on to open and close .
Nov 20, 2012 | 1994 Chevrolet Corvette
Left Vents blow warm/hot air when calling for cold air
Usually a sign of a faulty blend door under the dash.
The blend doors direct air thru the ac and heater core along with the upper and lower vents.
Sep 12, 2012 | 2009 Chevrolet Silverado 1500
I have a Ruud air conditioner model #13AJA36A01757. The temperture out of the vents is only 70 degrees while it is running. Outside unit, low side is very cold, and the high side is not hot, not even...
If your vents are in the floor, you need to inspect your return air ductwork, you may have some air leaks pulling hot attic air in thru the vents. If the supply vents are in the floor, the return duct may run through your attic, if the duct work is uninsulated or pulled apart, it will pull hot air thru the return, causing a mixture of cold and hot air, giving you a warm air movement through the ductwork. Many service men will not catch this problem. You need to turn the unit on, go up in the attic and visibly inspect the entire return air. I hope this helps you. mark
Aug 14, 2011 | Ruud Heating & Cooling
Finding a suitable thru the wall air conditioner
Not exactly....if you can half or more of the side vent exsposed then you will be okay...I like the side vent models because they are less prone to recycling the air...they either pull in the side and expell out the back or visa versa...
On the total back models all the air is just pulling and pushed out the back and they are prone to overheating in some wind conditions...the air just recycles...
Of course the main problem is that most people fail to keep their unit cleaned properly and that causes the overheating...
Window Air Conditioners - Clean them every year
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
heatman101
Jul 20, 2010 | Kenmore Heating & Cooling
Air blows out thru the vents but just no hot air, aslo i have to hit the dash for the air to come out thru the dash vents at times.
sounds like bad acuator motor, this is what moves the door in heater box to set hot or cold air, and other motors to set air to blow thru defrost, vent or floor. good luck.
Oct 10, 2009 | 1999 Chevrolet Silverado 1500
2002 gmc sierra blows Hot air thru ac vent on drivers side. Whats going on? Setings are set for cold air and we are getting cold air thru vents on passenger side.
We have this fairly often on our gm fleet with dual air controls. Replace the actuator and you will be good again (for a while!)
Sep 25, 2009 | 2002 GMC Sierra
Jeep AC blows cold air at defrost and feet but not through vents
There is a flap that directs the air. the flap is controlled by a vacuum actuator. This is located inside the venting. The actuator is connected to little vacuum hoses that attach to the temperature control switch. Either the flap is stuck, or the actuator has gone bad.
Jul 01, 2009 | 1999 Jeep Grand Cherokee
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Cold Air Penetrating from around & thru GE Zoneline 2100 Unit
There is a baffle/damper that allows outside fresh air to flow through the unit. This is only supposed to be open in cooling mode when the outside temp is moderate, or whenever you want just fresh air and fan operation.
Find the lever that controlls the baffle.
Some units have a switch in the control panel for this.
Jan 19, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Refrigerator not getting any air, (it is warm), freezer seems ok
so you mean the vents in the refer/frezer sections? yes ok there is a fan in the frezer section that moves the air thru out the box.its called the evaporator fan.you should hear a vissssss sound when you open the doors.some boxes you have to push the door switch closed with finger because fan goes off win door open.test fan with volt meter,should get 110 volts[may have to push that door switch in when testing]if voltage and not turning get new fan.hope that helps God bless ,tom
Jan 05, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenwood KW85 Air Conditioner Logo
78 people viewed this question
Top Kenwood Heating & Cooling Experts
john h
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
