Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Ice maker not producing ice,already check the basic problems,
The water started over flowing out of the ice maker,shut it off for several hous while at work. Turned the water back on now it won't produce any ice.
    Scholar:
  • 44 Answers
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Posted on Jun 06, 2010
Ice maker quit, does the power start relay control the water valve
Hi
If the ice maker has completely stopped producing ice ….
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
If the ice maker is producing ice poorly ….
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Sep 01, 2010 | Kenmore Refrigerators
Ice maker will not produce ice, no water flowing to dipenser.
Sounds like the water filter is plugged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Aug 29, 2009 | Kenmore Refrigerators
Refrigerator not making ice/freezing stuff
Hi..
In this problem you need to check this parts
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.Good luck.
ICmanServer
Jul 31, 2009 | Whirlpool Refrigerators
Replaced icemaker with new one but still not working
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
LG refrigerator french door icemaker not working
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
Jan 06, 2009 | Refrigerators
Ice maker won't quit dispensing ice cubes don't have ice skates!
Dec 11, 2008 | Amana Refrigerators
Ice maker stop making ice for kenmore 106.56352500
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
Oct 10, 2008 | GE Refrigerators
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
214 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
