Question about RCA 32V550T 32" TV
Losing picture on tv!
I just recently inherited a tv from my cousin and it is a 36in RCA (old school tv). Once I hooked the tv up with the coaxial cable I had picture and sound. After about 10 minutes I lost the picture and the screen had horizontal lines appearing sporadically. For some reason, the tv then did not recognize the channels that my cable provider offers. I shut the tv off for about an hour and tried watching the tv again. When it fired up, the picture and audio were there again. Also I was able to go up and down the channels with the remote. After about 20 minutes the picture started to become uneasy and started to turn into the horizontal lines I saw earlier. I feel like my tv is losing picture for some reason and I have no idea why this is happening. Is there something I can order to have installed to fix this problem? Any suggestions please help!
Thanks kindly.
  • 934 Answers
The ITC008 chassis is commonly riddled with poor solder connections. Good soldering station, patience and some good light and magnification and you might be able to fix it... Or you could spend a few dollars and run it into the shop and have a tech do it! It's not an expensive repair.
Bill
Posted on Apr 26, 2008
It has sound but no video
If it's the TV on the picture, It would be cheaper to by a new set. I repair TV's and old school picture tubes are very hard to find and not worth the time to replace. Flat screens show better and use a 3rd of the energy.
Feb 28, 2015 | RCA 27R411T 27" TV
I have 36in rca tv from 99 and my tv screen keeps blinking.
Might be a power supply/transformer problem. With the prices of TV's as low as they are today, it is probably more cost effective to replace rather than repair. I just recently bought a 40" HD flat screen with all the bells and whistles for $299. It would probably cost you close to that to repair your 15 year old unit. Food for thought.
Dec 24, 2014 | RCA Televison & Video
How do you connect a ps2 to the led24916dvdfhd
Well the LCD or TV must have rca..jacks yellow video..red and white is audio..if not u can get a component jack wires for PS2..red.blue..green...video....red and white audio..the TV must have those connections ..for PS2..or get old school cable connected hook ups for PS2..hooks in cable or antenna connecter on TV..UHF connected for ps2
Jul 21, 2014 | Video Game Consoles & Games
I have a RCA 32V432T 36in...the screen is light blue with white horizontal lines...it looks like a film in front of the actual picture...there is still audio though. what's going on?
Hello
There are two main causes for this fault. The first one is, advanced screen voltage to the screen grid of picture tube. The second one is leaky blue video output transisotr.
Just open your TV, and locate the screen control. It usually can be located with LOT [Line Output Transformer]. There will be two adjustable controls integrated to this LOT, marked as screen and focus. Out of which, the lower one will be for screen adjustment, and the upper one for focus adjustment. Just rotate the screen control [the lower one] to a little counterclockwise, so that the thin horoizontal lines on the screen just fade of. Adjustment is critical and should be done with care, and a small movement may just be enough. If it does not help you, repalce the blue video output transistor. This part can be located at the bace card [the printed circuit board fitted to the neck of the picture tube]. Locate it, replace it. OK.
Apr 17, 2011 | RCA 32V420T 32" TV
I have a rca 36in model number f36705 was just given to me has picture but no sound at all
There is a switch in the back of the tv for internal and external speakers. check to see if it is on the internal position.
Feb 17, 2011 | RCA F36705 36" TV
Wii hook up to time warner cable box with a dvd
I needed another part... an RCA cable splitter to put two cables into the same TV connection.
Nov 09, 2009 | RCA Televison & Video
RCA model P60812BL 10 years old picture goes fuzzy once on
Your convergence amplifiers are begining to malfunction. This is not expensive However I would advise that you get a qualified TV technician to work on the set due to a chance of damaging you TV if you install the amplifiers incorrectly.
I hope this helps
thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | RCA D52W19 52" Rear Projection Television
Dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Jan 10, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
Can't hook up DVD player to RCA TV?
please re chech ur input cables
Dec 25, 2008 | RCA 27R411T 27" TV
PS2 showing no video on TV, but I do get the audio
Make sure the male plug which is plugged into the PS2 Console is put in properly so push it in harder This has always happened to me that fixes it!
Hiope this helps - Josh
Feb 02, 2008 | Sony PlayStation 2 (PS2) Console
RCA 32V550T 32" TV Logo
134 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
