Question about Maytag MSD2756G Side by Side Refrigerator
The ice and water dispenser of the door is locked on after hummin
We heard a loud humming and looked and the light and crush ice dispener are locked on. we cant change or turn it off. no ice is coming out but it is locked on that setting....help....is a fuse blown or something like that? mark
  • Maytag Master
  • 3,740 Answers
Mark check for a door switch on the cabinet side oft the freezer door. It usually is near the hinge fold area of the door. Depressing the plunger should make the freezer compartment light go on and off. The switch also controls the icemaker auger power by shutting it off when the door is open. If the door switch has failed you will not get ice or water from the door dispenser. There are 2 plastic lock tabs of the side of the door switch to remove it. Use a knife blade or putty knife to unlock the tabs on the switch. If you need more help as to location of the switch respond here and I will pass a link for the diagram.
Posted on Jun 05, 2010
  • ragarwal496 Sep 17, 2010
    This does not really help. Depressing the switch makes the refrigerator light go on/off as they should. However, the switches for the light and the ice dispensor are still locked...
    Does this switch come out. Can it be replaced? How? Thanks
Ice dispenser will not dispens ice . light dims when pushed. ice maker works fine
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
Apr 23, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Ice is made but dispenser does not spin so ice wont drop
Hi, Remove the ice bin. With the freezer door open, push the door button and then push the ice dispener button to see if the auger motor is turning. If it does turn, check and see if there is something in the ice bn blocking the auger.
Please try this and let me knwo.
Thanks
Vic
May 24, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker dispenser and frost
outside moister cause making frost, probably you can not do it youself,if you know , do it.
Jun 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Mar 21, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
243 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
