Question about Sharp AL-1641CS Laser Digital Copier
AL-1631 send me the singn h-4
The machine send me the sign H-4, i introducting the code and not has the solution...That I should do???1631 sharp.
  • 29 Answers
Just press c-exposure-c-exposure-c the machine will shutdown and type 14 then press star key.if the sign still ther.the heater lamp or the thermostat in fusing unit are defective.
Posted on Apr 10, 2008
My sharp al 1631 did not make the copi the machine codig is h4
press # * C * the machine will enter diagnostics. Then enter 14 and follow the directions to clear an H4 code.
Feb 06, 2011 | Sharp AL 1631 Copier
I HAVE A SHARP AL 1631, IT SHOW ME A 4 CODE, HOW CAN I TO SOLVE THIS
their is no A4 code,if you mean H4 try to reset it by simulation 14
Dec 26, 2010 | Sharp AL 1631 Copier
Sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Nov 16, 2009 | Sharp AL 1631 Copier
Sharp al-1631 drum sign
This simply, You it is necessary to extract the drum from device and sprinkle the scraper , toner. Afterwards tested rotate the drum for anything numbered six manual and when squeak will disappear the insert it in device.
Sep 16, 2009 | Office Equipment & Supplies
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
SHARP AL-1631 DIGITAL COPIER SHOWS ON THE SCREEN CODE H4 WHEN SWITCHED ON.
Hello sir; You do need following procedure to reset; once begun procedure must enter within four seconds; Press "clear", "exposue mode", "clear", "exposure mode" these 4 keys within 4 seconds, then enter 14, then press start, should take care the problem.
Jun 12, 2009 | Sharp AL 1631 Copier
Whow to claer code
i repear sharp canon copier please send me details xptareq2000@yahoo.com
May 30, 2009 | Sharp AL 1631 Copier
Sharp AL-1631
Fuser is not heating up. Normally a broken bulb.
Unless you can get hold of spares, call the engineer.
Feb 13, 2008 | Office Equipment & Supplies
Sharp AL-1641CS Laser Digital Copier Logo
71 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
