Question about Maytag PAV2300 Top Load Washer
WATER IN WASHER WONT SHUT OFF
MY WASHER WATER WONT SHOT OFF IT JUST KEEPS RUNNING EVEN WHEN WASHER STARTS SPINNING WHAT DO I NEED TO LOOK AT TO FIX THE PROBLEM
  • Maytag Master
  • 3,740 Answers
Hi and welcone to FixYa. I am Kelly. When water wont shut off no matter what you do the problem is inside of the water valve assy. Usually there is a small bit of debris in the diaphram center hole that is holding the water passage open.
Here is what you can try to do to clear if BEFORE replacing the eater Valve.
1. Get a bucket
2. Turn off both water supply hoses momentarily
3. Set the water temp to warm
4. Remove ONE hose from the wall connection and place the hose in a the bucket.
5. Turn on the remaning connected hose/
6. Start machine fill cycle and tap the hose connection at the water valve on the back of the machine with either a screw driver or hammer handle.
Timer OFF
REVERSE HOSE CONNECTIONS ON THE WALL CONNECTION.
7. Place the other hose in the bucket
8. Start Fill cycle.
9. Again tap the hose connection at the water valve
10. Stop timer.
11. Reconnect both hoses and test for water flow with timer off.
12. Start fill cycle
13. Rapidly select hot and cold wash water.
14. STOP fill cycle.
15. Remove each hose individually from the water valve one at a time.
16. Use a knive blade and remove the inlet screen from the water valve. Wash screen under slowly running water rubbing it clean with your fingers. Re install screen. Reconnect water hose.
17. Repeat step 16 for opposite hose and screen.
18. Turn on water supply.
19. Test for proper filling and water stopping by starting and stopping fill cycle.
If it works you got lucky. If you still have the problem you will need to change the water valve. Either one of these water valves will work on your machine:
http://www.repairclinic.com/Appliance-Parts?s=t-PAV2300-%3d%3dc292d509361
Thanks for using FixYa.
Kelly
That is about it
Posted on Jun 06, 2010
The water will not drain. The tub starts
The pump is clogged. The only way to fix this is to clamp off the hose to the tub and remove the hose from the pump and remove what ever clogged the pump. Expect to get a little wet.
Mar 04, 2010 | GE WBSR3140DW Top Load Washer
The cold water often will not shut off even when power is turned off on my Fisher & Paykel GWL08 washer. It must be turned off manually. Is the problem the input valve, and where do I get a new one?
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Post your model number(http://www.appliancepartspros.com/modelnumber_loca tor.aspx ) HERE and search for water inlet valve > http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GWL08
Or you can go to an appliance parts store.
Sep 28, 2009 | Washing Machines
The water does not shut off even after it reaches the proper level it continues to run and it overfills and leaks out the bottom of the washer the clear hose is not clogged and we blow into it we can hear...
Sep 14, 2009 | GE WVSR1060A Top Load Washer
Water keeps running into my washing machine. Even
Water valve is stuck open, probably by lime or calcium build-up. Proper fix is to replace the water valve. How old is the washer?
Jun 11, 2009 | Washing Machines
The water wont shut off
Check water valve. Solenoid may be stuck. This is where your hoses attach to, all one unit.
May 25, 2009 | Kenmore 24032\24036 Top Load Washer
Washer leaks and keeps shutting off when it starts to spin.
 it sounds like your washer is not draining before it starts spinning. the machine should not have visable water in it when it starts to spin. make sure there is no water in the machine and that it is draining properly.
Jan 27, 2009 | Kenmore 23822 Top Load Washer
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
No Spin
Hey, I know it's probably late, but I'm having a similar problem in that it's not spinning and I'm getting an error message of F 02. Did you have this problem? How did you fix yours? Please let me know, I need to wash clothes for my son's prom tonight. Thanks.
Oct 20, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Maytag PAV2300 Top Load Washer Logo
353 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
